Timing?
Old Aug 7, 2009 | 10:32 AM
  #76
alanoo's Avatar
Originally Posted by Area47
the street doesn't show a 2 hp gain from 1 degree of timing being increased.
the street doesn't show a 10whp gain from an afr change.
Beh, you only see 2hp per degree ignition adv ?
(saw a lot more on my N/A actually)
Old Aug 7, 2009 | 10:46 AM
  #77
freakta's Avatar
it could be a general number... or he could be seeing that above 25degrees adv. you never know
Old Aug 7, 2009 | 10:50 AM
  #78
alanoo's Avatar
Yep of course
Old Aug 7, 2009 | 11:14 AM
  #79
Zach06CobaltSC's Avatar
You won't see more then 2hp per degree of timing you run generally. And yes tuning from 05-07 is the same, there all lsj's.
Old Aug 7, 2009 | 11:16 AM
  #80
Snakes709's Avatar
From what i understand u buy hptuners....think its like $400 for no the non pro version? And u have to buy credits to be able to tune a car...thnik cobalts take 2 credits? Once u buy those credits for the car then thats it...u can tune as much as you want. But if u wanted to tune another car u need to buy 2 more credits.
Old Aug 7, 2009 | 01:01 PM
  #81
WickedSS2005's Avatar
07's are a little different
Old Aug 7, 2009 | 01:12 PM
  #82
07touringcoupe's Avatar
What's different
Old Aug 7, 2009 | 01:30 PM
  #83
ShortStack's Avatar
They are different, and some have different tables.
07 is a 32bit OS while the 05-06 is 16bit.
Old Aug 7, 2009 | 01:34 PM
  #84
I'm guessing os is operating system. Why did they do that?
Old Aug 7, 2009 | 01:36 PM
  #85
BLAZIN07SS's Avatar
I'm too JDM for you
emissions BS.
Old Aug 7, 2009 | 01:39 PM
  #86
I was just about to post that. What was it pose to do that it didnt
Old Aug 7, 2009 | 02:51 PM
  #87
Area47's Avatar
Rent me! per hour
bet me.
alanoo. it was a generalization
Old Aug 7, 2009 | 08:07 PM
  #88
Stiner's Avatar
there's a bunch different from 05-07 in the torque management region
Old Aug 7, 2009 | 10:05 PM
  #89
Right but the way you go about tuning them is the same. Tuning all of the lsj's is about the same, tuning lnf's is a lot different, in my opinion at least.
Old Aug 7, 2009 | 10:48 PM
  #90
IMO, LNF is a cake walk. Stock wb ftw. Of course, there is more to be desired by the tables avail from HPT currently.
Old Aug 8, 2009 | 03:48 AM
  #91
383_Stroker's Avatar
troof x 2
Old Aug 8, 2009 | 05:39 PM
  #92
Area47's Avatar
Rent me! per hour
they are to a degree. then you get into the maf scaling side of it and all hell breaks loose. then some fucked up table in the background says "**** you" and ruins the fun
Old Aug 8, 2009 | 07:29 PM
  #93
Snakes709's Avatar
Whats the most timing anyone is running? im at 24* right now...getting retuned tomorrow to adjust the afr for my header/dp/exhaust but im also going to bump it up to 25 or 26* of timing. So im just curious...and i know the lsj like to make power past 25 so dont tell me that.
Old Aug 8, 2009 | 07:46 PM
  #94
Area47's Avatar
Rent me! per hour
you won't run the afr lean enough to make use of anything past 25.5 degree's of total timing. so if you want to run 27 degree's. be my guest. your rod bearings will hate you later
Old Aug 8, 2009 | 08:20 PM
  #95
Snakes709's Avatar
so im guessing the answer is 25...lol
Old Aug 8, 2009 | 11:26 PM
  #96
freakta's Avatar
its more about timming against afr... you can run a ton of timming if you have a low afr, if you start to lean it out you see heat, knock and have to run less timming... to way to get good numbers is to run the strongest afr with the most timming (up to 25.5*) with no knock, and no heat...
i think im getting this a bit more each day... if im wrong please tell me cause i dont wanna be that wrong
Old Aug 8, 2009 | 11:40 PM
  #97
you're on the right road
Old Aug 9, 2009 | 12:03 AM
  #98
Snakes709's Avatar
so if im running 11.9afr and 24* timing with 140iat2 after 3 pulls on the highway and no kock...should i leave it at that or change something? the guy tuning me knows alot but im trying to learn more about it for myself
Old Aug 9, 2009 | 12:06 AM
  #99
light'bolt's Avatar
I wonder if his location has anything to do with his unusual timing
Old Aug 9, 2009 | 12:11 AM
  #100
Snake: you're fine right there. is that on methanol or not? I would assume so
