timing?
Old Jan 28, 2010 | 02:54 PM
advise's Avatar
timing?
ok so im about to time my engine i lined up the mark on the balancer and timing cover, removed the cover(crank sprocket mark was at 5 o clock), i put the intake cam at 2 o clock and im about to put the exhaust sprocket on at 11 o clock. im just unsure if i did the break down correct. when lined up the balancer and timing cover i didnt check if i had compression so could my engine be 360 out and on the exhaust stroke instead of the compression stroke?
Old Jan 29, 2010 | 10:41 AM
advise's Avatar
Old Jan 30, 2010 | 05:57 PM
advise's Avatar
plz help
Old Jan 31, 2010 | 11:33 AM
Jazer's Avatar
http://gmtunersource.com/index.php/r...lsj-build-book
I believe they give you a break down of steps in the build book. The link has PDFs of the 6 chapters. I used this as well as the Cobalt Haynes manual and Alldata when reassembling my engine. Used all of them in tandem so I can't say which was best for what part of the process, although this may help. So check it out. Been about a year since I timed the LSJ, can't remember the exact steps I took, don't want to steer ya wrong.
Old Jan 31, 2010 | 11:41 AM
advise's Avatar
ya i just wanna do it right once. thanks for the info i have a haynes, but i wanna j see if its possible that my motors 360 out
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
