timing chain tensioner
Old Jan 18, 2010 | 11:39 PM
advise's Avatar
whats the best tool to use to press against the chain guide to release it, last time i did it i broke my chain guide using an extension , any thoughts so i dont have to make a project out of this again
Old Jan 19, 2010 | 12:32 PM
advise's Avatar
Old Jan 19, 2010 | 12:34 PM
JapEatr's Avatar
South Central *********
tap the back side (1 1/4" head) with a rubber mallet.
also turning the motor one tooth can also release it, but it is easier to just smack it with a mallet or wrench
Old Jan 19, 2010 | 01:55 PM
advise's Avatar
i thought you have to compress it
help!
Old Jan 19, 2010 | 03:28 PM
JapEatr's Avatar
you compress it by hand or gently with a vise PRIOR to installing it in the engine. Then release it to get tension on the chain.
if trying to release tension to remove the chain, simply remove the tensioner from the block.
Old Jan 19, 2010 | 03:49 PM
advise's Avatar
i understand that i thought that you have to compress the tensioner 2mm to get it to release and apply tension to the chain, i guess ill give this a shot since i last time i pushed on the chain guide with and extension and i couldnt get it to release for anything, this was instructions from the gm build book.
Old Jan 19, 2010 | 03:52 PM
JapEatr's Avatar
if everything is in place, smack the back of the tensioner (the nut side) with a mallet.
Old Jan 19, 2010 | 07:40 PM
advise's Avatar
alright ill give this a try once i get my chain guide
thanks
bump for other suggestions
Old Jan 19, 2010 | 09:12 PM
JapEatr's Avatar
if it wont release you can try rotating the engine so that the cams move 1 tooth, this motion can also set the tensioner...but not my favorite way
also out of curiousity are you using a new redesigned style tensioner, or the shitty original?
Old Jan 19, 2010 | 11:39 PM
advise's Avatar
new one and when i changed it like the gm build book says to compress it 2mm until it released, in doing so i broke the nylon off the chain guide so i gotta replace it first
Old Jan 20, 2010 | 12:19 AM
scotch89's Avatar
the build book??/?the one that shows u how to build it to 300hp?
where is the new tensioner???is this the right one?http://www.crateenginedepot.com/stor...P2216C133.aspx
Old Jan 20, 2010 | 12:58 AM
StreetDreamz's Avatar
An 18" long, 1/4" wide rod and a hammer. Quick little jolt right on the chain where it sits on the guide. Works like a charm :-)
Or you can be a man and drill a hole in the middle of the tensioner bolt, tap it to a 12x1.75mm or or 7/16-14 or so hole, thread a 3.5" long bolt into it with a jam nut near the top and crank the bitch down until the chain is good and tight with no more than 1/4" deflection. No more worries about slop in the tensioner causing a jumped tooth. Just give her a good 1/4 turn every 1,000 miles or so and no worries.
Old Jan 20, 2010 | 01:15 AM
advise's Avatar
idk im scared i did the hammer and a long extension and broke the guide
Old Jan 20, 2010 | 08:44 AM
JapEatr's Avatar
That is the new one! Your are good to go!
Old Jan 20, 2010 | 12:34 PM
scotch89's Avatar
thanks man .............
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
