Timing Chain/Timing Belt (Whatever they have)
Old Aug 5, 2011 | 11:49 PM
SlowCobaltSS's Avatar
So what's the average mileage that you should get it replaced in a ss/sc?
Old Aug 6, 2011 | 12:14 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I don't know that the chain should ever need to be changed. I highly recommend changing the stock tensioner out for the new design tensioner though.
Ecotec Timing Chain Tensioner 12608580 - Crate Engine Depot
Old Aug 6, 2011 | 12:50 AM
rivaladore's Avatar
Yes I would do that ASAP if you haven't already
Old Aug 6, 2011 | 01:10 AM
Whats the reason behind you two saying to replace it>?
Old Aug 6, 2011 | 03:04 AM
The stock, original design tensioner is prone to failure... and when it fails, not only is you chain then loose, but the tensioner has a habit of falling apart, dropping parts into your bottom end.
Old Oct 28, 2011 | 08:17 AM
stonny9's Avatar
Well I tought my 05 was safe until 4 days ago when a rattle started. I have 76k. It has gotten worse so I parked it yesterday when I diagnosed it so I dont have to do any head work. I sourced all the parts from rockauto for $160 ship.t including oem tensioner, chain, 3 guides and gasket set. Better to replace everything since I do a lot of high revs. My bro in law went 300k in his 1994 silverado before he changed the chain. It is the belt that you really have to worry about after 100k.
Old Oct 28, 2011 | 10:59 AM
rivaladore's Avatar
Umm you better hope that tensioner from rock auto is the revised one. Make sure it looks like this if not don't put it on.
Old Oct 28, 2011 | 07:14 PM
stonny9's Avatar
thanks for the info that is why I went with the OEM acdelco tensioner so I could match the part numbers. It has the same part that is listed. In ur link and multiple other posts
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
