timing hp tuner
Old Sep 25, 2007 | 06:09 PM
blacksssc06's Avatar
timing hp tuner
i just wanted to see some of your timing maps for the high octane im just trying to get a idea of what some people are running also if you post one please leave your mods done to thanks mike
Old Sep 25, 2007 | 07:08 PM
Maxim_X's Avatar
I don't have my map, but I'm running 23* @wot on 93 . I have 60's, 2.8, duall pass and cobra, and catless DP. Oh yeah, not a hint of knock. But I'm kinda rich, real low 11's to maybe 11.5
Old Sep 25, 2007 | 07:11 PM
shaunmcdee's Avatar
i dont have hptuners on this pc, but i have a modded stage 2 map with 6 degrees of timing added everywhere. My top end is all 25 degrees.
im a 2.6, with meth. No knock.
Old Sep 25, 2007 | 09:25 PM
can use guys explain to me how i read the cylnder aimass like what 0.08 i mean iknow the rpm
Old Sep 25, 2007 | 10:11 PM
Infernokron's Avatar
Your spark tables are based on how much air you have in the cylinder at a given RPM. So if I'm at 2,000 RPM and have 0.12 grams of air per cylinder, then I'll run 36* of timing. That's the base timing, before IAT modifiers etc. Now if I'm still at 2,000 RPM, but I suddenly go WOT, and I'm running 1.32 grams of air in the cylinders now, I'll run 1* of timing. Again that's before your modifiers. Those numbers are just made up btw (happen to be what's in my spark table). The general rule is the more air you have in the cylinder at a given RPM the less spark you have, while also the more RPM's you have per amount of air the more timing you have as well. In other words, lots of air at low RPM = very little spark advance. The more RPM's you add the more timing you can add as well (assuming you don't change anything else, IAT's, amount of air, etc.). If you open up the histograms in the scanner it has how much actual timing your running (averaged out) per RPM/(g/cyl). It's the same table as your spark advance tables in the editor, except it shows what your actually getting after all your modifiers.
The grams per cylinder is just how the computers happens to measure the air for that particular table.
This is my High Octane Spark Advance table, it's deffinatly still a work in progress. My mods are in my sig. I've only been tuning for between 3-5 weeks (havn't bothered to keep track). So keep in mind that I may be wrong on some of this stuff, I'm still learning things too hehe.
(Click the picture to DL my table in .txt format)
When you say your running 23* at WOT, is that across the board or peak? Looking for more info on spark tables now that I'm messing with mine hehe.
Old Sep 25, 2007 | 10:16 PM
an0malous's Avatar
my actual timing after modifiers, builds from 23* to about 27-28. no knock.
Old Sep 26, 2007 | 10:45 AM
kool thanks this helps out a lot
Old Sep 26, 2007 | 11:45 AM
Area47's Avatar
Rent me! per hour
anything over 25 degrees up top is pointless.
mine starts at 2k hits 27 degree's, and ramps down to 25 at 7k
2.8
pissed off 42's
meth injection.
Old Sep 26, 2007 | 04:12 PM
an0malous's Avatar
why is this?
Old Sep 26, 2007 | 04:18 PM
Area47's Avatar
Rent me! per hour
Originally Posted by an0malous
why is this?
the added pressure on the crank and rod bearings is not worth the .3 hp. i played with some timing last night on the dyno. my highest hp numbers came from 24.5 degrees of timing from 5500-7200.
Old Sep 26, 2007 | 04:23 PM
Jimmys2007CobaltSS/C's Avatar
do u have hp tuners??
Old Sep 26, 2007 | 04:24 PM
an0malous's Avatar
very interesting.
but what about racegas + timing.
your gonna get alot higher than 24.5...
Old Sep 26, 2007 | 04:27 PM
Area47's Avatar
Rent me! per hour
very interesting.
if i run 11.5 a/f i can run 30 degree's if i wanted.
water injection kicks ass.
Old Sep 26, 2007 | 04:29 PM
an0malous's Avatar
yeah but you just said it does no good lol.
i dunno it just doesnt make sense in my head.
I can run 27-28*, no knock with stock cooling and no injection.
Old Sep 26, 2007 | 04:35 PM
Area47's Avatar
Rent me! per hour
in short, back your timing down 3 degree's, you won't feel the difference in the butt dyno. if you have the time and the money, id suggest playing on the dyno to find out what your car likes for timing. it may want 27 degree's every car is different.
im runnin a 2.8/42 set up.
Old Sep 26, 2007 | 04:40 PM
an0malous's Avatar
hmmm thanks for the info man.
im actually thinking seriously of some dyno time over the colder months.
Old Sep 26, 2007 | 04:51 PM
yeah
Old Sep 26, 2007 | 06:59 PM
Maxim_X's Avatar
It peaks @ that, I think it builds from about 20* @3k.
Old Sep 26, 2007 | 09:41 PM
im thinking about lower boost like 18 and run alot more timing i hear these cars like lower boost and more timing im running 20psi at 25*
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
OPCrer
Sep 27, 2015 08:11 PM
