torqing manifold
Old Feb 8, 2008 | 09:51 PM
brownbandit9's Avatar
torqing manifold
1st my zzp header/downpipe combo did not come with a gasget for the manifold to engine was it supposed to.. should i use the old one or buy new one...also do i need to torque the bolts on headers down to a specific pressure or just get them tight..
Old Feb 8, 2008 | 09:52 PM
firestorm's Avatar
reuse the old one if its not torn. it has a metal ring, so if its intact, its fine.
Old Feb 8, 2008 | 09:56 PM
11secSRT4's Avatar
Your able to reuse the stock gasket.Make sure all the bolts are in and started by handbefore tightening. Tighten the header first from the center and work your way to the ends. Enjoy
Old Feb 8, 2008 | 10:37 PM
RollOver360's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-gm-performance-parts-extrude-honed-exhaust-manifold-install-70397/
That should answer all ur questions.
later
....the search is ur friend.....
Old Feb 8, 2008 | 11:18 PM
yah iv read that thing like over 4 times..doesnt say anything about a zzp header coming with or without a gasket does it
Old Feb 8, 2008 | 11:21 PM
an0malous's Avatar
comes with header-dp gasket, and dp-catback gasket.
no engine-header gasket.
either buy a new one....like $10-15
or if the old one is still in good shape, just reuse it.
D4u2s0t's Avatar
it doesn't come with the gasket. like said, you can reuse the stock one unless it looks damaged.
as far as torquing the bolts, the header bolts only need to be torqued to 10 ft/lbs. if you don't have a torque wrench, or aren't familiar with torque ratings, 10 ft/lbs is not a lot at all. basically you want them to be snug, and that's it. \
Old Feb 8, 2008 | 11:41 PM
Well that link was for the question that u had about tightening down the nuts on the studs that hold the header to the block. Gives u the torque specs and the pattern. U could of found out about the gasket if u did a search also because it has been discussed SEVERAL times.
later
Old Feb 9, 2008 | 01:31 PM
i did search but i wanted to know about the zzp header specific...when i did it i got nothing i even re read the 90 page group buy thread on the product...so believe me i searched
Old Feb 9, 2008 | 06:29 PM
Originally Posted by Zooomer
Kit's do not come with gasket to the head. That stock one is copper and reusable.
On page 54 of the group buy thread. All i did was find the thread and then did a search within the thread and there it was.
later
Old Feb 10, 2008 | 08:24 PM
thanks man..you proved your point like 2 responses ago..your saying this in a kinda dick way...
Old Feb 10, 2008 | 08:29 PM
tsunam1's Avatar
It takes a minute for these things to update, don't take it personal.....
at least you weren't worried that the gasket primaries are smaller than the new pipe, since they are the same size as the heads.....
Old Feb 11, 2008 | 02:51 PM
well i didnt think about that.ahahh and i already dremeld the gasket wholes to fit to the headers..oh well its already in so..im getting a flapping sound i hope its not from my dremel work....im hoping its the gasket from dp to exhaust..it was 2 big and buckled up when on the studs and i just clamped it down in there anyways..
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
