torque specs supercharger bolts
Chipmonk, no problem. Why was there water in the manifold?
[QUOTE=2K5SS/SC?;1374321]I don't know how you did that especially since they are torque to yield bolts and will snap pretty much after 18ft.lbs.
QUOTE]
I've overtorqued bolts many times more than factory specs have said to either cause torque wrench was off or I wanted them tighter.
I bet I could easily have torqued them to 50 and not had them snap either.
I used a 4 foot breaker bar to try and remove my blue stage 2 security bolts the tech used red loctite on which was easily 200 ft lbs with that 4 foot breaker bar and those bolts didnt snap. A red loctited takes 395 ft lbs to remove without applying torch heat to them.
Most torque wrenches wont even read properly below 20 ft lbs anyway, so its a crap shoot even if you are using a torque wrench unless its a very expensive one. I just went to the max for a grade 12+ bolt.
15 ft lbs if someone actually got that accurate of a reading is probably just fine, but I know a couple peoples who's bolts loosened up. I sure would use blue threadlocker with whatever torque was used.
M8x1.25x13 bolts are rated at 17 ft lbs for grade 8.8 bolts, 24 ft lbs for grade 10.8 and 29 ft lbs for grade 12.9 bolts.
Thats ok, go find the metric bolt size torque chart and see what the "correct" torque spec is for these bolts instead of believing GM's instructions. There isnt a GM tech around that is gonna torque them to only 15 ft lbs per those instructions.
Not really trying to debate the issue here but only 15 ft lbs and no threadlocker according to instructions on bolts that are subjected to 7000 rpm vibrations frequently is ridiculous.
actually I'm a GM Tech, and I installed my supercharger bolts to spec.....and I have yet to have any problems. I mean if that's how you do it, more power to ya....but I'd hate to have some people come here to try and learn how to do something and read your post and then do as you say and wonder why they snapped the bolts
