Torque Steer
Old Oct 20, 2005 | 03:25 PM
Asstyme's Avatar
Torque Steer
If I were to install a WEAPON*R Engine Damper would this help eliminate any torque steer ?
I've had my SS SC for 3 days now and although I have kept the rpm under 4500 I still notice great torque steer especially when turning under accceleration. It seems to pull hard into the turn.
I do have the LSD. This is my first front wheel drive car so maybe I'm just not used to it but I'm thinking when I do get the car broke in and get to hammer it the torque steer will be much worse (scary thought).
Also does anybody know where I could get the WEAPON*R Engine Damper for the best price ?
Peace
Old Oct 20, 2005 | 03:29 PM
MarcS's Avatar
The Stig
Check out: http://www.ironmandevelopments.com/
I think you'll find what you're looking for.
zinner's Avatar
Moderator Alumni
Nope welcome to FWD. Hold on to the wheel tigher
Old Oct 20, 2005 | 03:30 PM
Ramps's Avatar
Torque steer is caused by one wheel getting more power or more direct power then the other. So if you have un-equal length CV axles the shorter one pulls/jerks harder. I would have thought the LSD would have greatly reduced the torque steer...i don't have an LSD and i have a bit of it too.
The dampener will help a bit, but it is designed to get power to the ground faster by minimizing engine movement...so it's not gunna do alot for the torque steer.
Old Oct 20, 2005 | 03:37 PM
Erod's Avatar
Moderator Alumni
Maybe you should wait till its broken in to see what its like before spending the money.
Old Oct 20, 2005 | 03:46 PM
zinner's Avatar
Moderator Alumni
BTW we do have equal length half shafts. The LSD only helps out if one wheels starts to slip.
Hmm I was just doing some reading and I read that the LSD can actually make torque steer worse.
Old Oct 20, 2005 | 03:51 PM
num482's Avatar
drive it hard to break it in.
Old Oct 20, 2005 | 04:18 PM
97cavie24ls's Avatar
worse.
actually they arent true equal length shafts , becuase the passenger side axle is still runs a extra shaft , with a extra bearing for support
it is a better system than with out the extra shaft and support , but still isnt true equal length
you also might want to watch your front tire wear , if the alignment is off a little it will amplify the TQ steer normal on front drives
the redline i drove with the lsd , when launched straight didnt tq steer , but if you hit the gas pedal at the wrong time , the tq steer would about rip the wheel outta your hand if your not watching in a corner
Old Oct 20, 2005 | 04:25 PM
Asstyme's Avatar
"the tq steer would about rip the wheel outta your hand if your not watching in a corner"
Yea, that's what I'm talking about.
ThanX for everybodys help
Peace
Old Oct 21, 2005 | 12:40 PM
Roger@AEM's Avatar
I had crazy torque steering in my turbo'd honda civic. I drove it for like 15k miles and then had the tranny rebuit and installed a KAAZ LSD. No more torque steer for me. That clutch pack diff really helped it out. The axles are far from equal length in my civic, since is the SOHC motor. I'm sure it would do the same in the Chevy.
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
