Trouble Code P0103 AGAIN!
Old May 31, 2006 | 12:22 PM
BlackSS/SC's Avatar
It seems that everytime I race someone I get the trouble code p0103. I had a Injen CAI on the car and I figured it was because of that but I now have my stock intake on it with the stock filter and it still happens. Make the car run like ****. I've got a GM Stage Flash and 42.5lb/hr Intense injectors and a 2.8" pulley. Any ideas?
Old May 31, 2006 | 12:26 PM
powerbalt4020's Avatar
http://www.obd-codes.com/trouble_cod...high-input.php
OniMirage's Avatar
huh what is the rating for the gm stage1 injectors?
Old May 31, 2006 | 12:40 PM
BlackSS/SC's Avatar
I think the GM injectors are about 42.08lb/hr if I remember correctly. I know what the trouble means but why am I getting it? I took the MAF out and it is clean and installed correctly. It only happens when I do a bunch of wide open throttle runs.
Old Jun 5, 2006 | 08:20 AM
BlackSS/SC's Avatar
Thanks for all the help
Old Jun 5, 2006 | 09:07 AM
BLKSS's Avatar
Aftermarket intake obviously. Main reason why I don't have one yet.
Old Jun 5, 2006 | 09:10 AM
CTCOBALTSSS's Avatar
No, he took the CAI off. He now has his stock air box and he is still getting this message. That's weird.
Old Jun 5, 2006 | 09:21 AM
2006CobaltSS/SC's Avatar
Spray the MAF sensor with some MAF Cleaner from a parts store. You may have a small amout of filter oil on the MAF Wires. I clean my MAF everytime I clean my Filter.
Old Jun 5, 2006 | 09:26 AM
BlackSS/SC's Avatar
I found out why I, and lots of people get this code. The problem is the car throws a code for anything over 10,000hz at the MAF sensor. Where I live and with a smaller pulley it goes over the allowed hertz.
Old Jul 5, 2006 | 10:08 PM
GeoChevyCobalt's Avatar
Please expand your explanation some more. I am getting this code every once in a while. It only happens at full throttle and on colder days. I am thinking that it is the MAF but not sure. I have no CA and GM stage 2 with 2.8.
Old Jul 5, 2006 | 11:23 PM
Toyotech's Avatar
so your pegging your maf at 5 volts?...or 4.8
Old Jul 6, 2006 | 06:55 AM
BlackSS/SC's Avatar
It is the MAF Fail Frequency, once you get up in the revs with a smaller pulley some of the car are going above 10 000hz and that the fail frequency. At lease thats what was wrong with mine. Once I got HP Tuners I put the frequeancy up to 11 000 and it has not happened again.
Old Jul 27, 2006 | 10:45 AM
NightriderCobaltSS's Avatar
This hasnt been posted on in a couple weeks but i used the "Search" and found this thread but i just got the code today came on once i past 6500 Rpms.
I cleared the code and when i restarted it didnt come back.
I looked at that site and it said
* Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
* Inspect for any air leaks near the MAF sensor.
* Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
* Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
* Replace the MAF sensor.
If i needed to replace the MAF how much do they cost ?
Old Jul 27, 2006 | 11:31 AM
bump .... It seems that Injen and K&N are both getting these codes
Old Jul 27, 2006 | 11:45 AM
Rodimus_Prime's Avatar
HP tuners, just turn it off the code, problem solved
Old Jul 27, 2006 | 12:12 PM
srt-killer's Avatar
I have Injen and no codes
Old Jul 27, 2006 | 12:19 PM
06blackg85ss's Avatar
HP TUNERS change maff freq to 12000hz no more problems.... with an intake you peg out above the 10000 hz limit on the stage setup..
Old Jul 27, 2006 | 12:23 PM
Doc's Avatar
Doc
Interesting, I've had the injen and gotten 1 code. The 0171 code and I cleared it and its never come back. That was after a day at the track almost running out of gas. On a side note, I set my frequency at 11500 and haven't had an issue.
Old Jul 27, 2006 | 12:26 PM
Tomtwtwtw's Avatar
Forgive me if I'm asking a dumb question, but I don't know much about this area of the car. Can this be avoided any other way besides HPtuners? Is there an aftermarket MAF that would have a higher tolerance? (or will there be?) Or is this setting in the car's computer, and the MAF is merely reading it? I'm guessing the latter if you can latter it with HPT.
Old Jul 27, 2006 | 12:44 PM
Doc's Avatar
Doc
The LT1 MAF can be used, although you'd need to change some of the settings and HPTuners is a way. I don't know the technical answer about the MAF, WOP posted something regarding this on the rl forum recently.
Old Sep 12, 2010 | 11:06 AM
superbrowndude's Avatar
Time to revive this bitch...
Ok so when I punch it in second gear I get this code P0103/P0304.
Im trifecta tuned without a 3 bar sensor,does what make any difference ?
And would better spark blugs correct the misfire ?
****,sorry wrong area to post this in
Last edited by superbrowndude; Sep 12, 2010 at 11:06 AM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
