TTR Mounts + Ingals Torque Damp
Old Jan 29, 2008 | 11:38 PM
wombat's Avatar
Searched, couldn't find anything...
Will the TQ Dampener fit with the TTR mount, or will I have to dremel off a little bit of the mount? I tried fitting it (Note: I didn't take off any screws, just eye'd it) and it looks like it's going to have some clearence problems near the single screw towards the front of the car.. Input?
Old Jan 29, 2008 | 11:43 PM
saunders1986's Avatar
why would u wanna use both? its unneeded......
Red2.4SS's Avatar
You shouldn't neet the Ingals with the solid mounts.
Old Jan 29, 2008 | 11:45 PM
wombat's Avatar
Well, the solid mounts aren't cutting it. I'm going to do some testing by putting my stock back on, and installing the ingals, doing some little test launches, then do the same thing with the motor mounts on. I still get some NASTY wheel hop with the solid mount.
Old Jan 30, 2008 | 08:31 AM
TurboTechRacing's Avatar
Do you have tranny mounts also?
You really need both the tranny mounts and the upper TTR mount...
Old Jan 30, 2008 | 09:13 AM
yellowspeed5's Avatar
I just have the tranny mounts from TTR that they work amazing....
Old Jan 30, 2008 | 09:21 AM
RaineMan's Avatar
solid engine mounts are a step above the torque dampner... you don't need both... it won't do anything and it's just extra weight...
Old Jan 30, 2008 | 10:25 AM
LopsidedJester's Avatar
tranny mounts are definitely the key, engine mount helps keep the engine still and looks good, but i don't think it helps as much with wheel hop
Old Jan 30, 2008 | 04:39 PM
wombat's Avatar
Yes, I have both...It doesn't really eliminate wheel hop. =/
Old Jan 30, 2008 | 04:41 PM
D4u2s0t's Avatar
then you need to learn how to launch better in your car.
Old Jan 30, 2008 | 04:45 PM
M-Dub's Avatar
I think most just need to learn to drive it's the best cure for wheel hop!
I have just the Ingalls and ZERO wheel hop for me!
Old Jan 30, 2008 | 04:57 PM
D4u2s0t's Avatar
yep. you just have to launch at a lower rpm, and slowly increase the throttle untill you can go wide open.
Old Jan 31, 2008 | 11:48 AM
wombat's Avatar
I've had numerous people try and launch my car, including my girlfriends dad who's been driving stick for 30+ years, it still hops. It's horrid at the tracks, but on streets it's not that bad at all...Even if I launch at a lower RPM, slowly hit the throttle, then go wot when I have traction, the thing still hops a little.
Old Jan 31, 2008 | 05:12 PM
Area47's Avatar
Rent me! per hour
boost control is your friend.
or just add more power
Old Jan 31, 2008 | 05:19 PM
RaineMan's Avatar
amen... the tranny mount does twice as much as the engine mount does...
Old Jan 31, 2008 | 06:49 PM
D4u2s0t's Avatar
if you have traction, it won't hop. that's the downside to buying a fwd car. get all the traction mods you can if you want wheel hop to go away.
Old Jan 31, 2008 | 07:03 PM
I have an 07G85 as well with TTR motor and trans mounts and 2.7" 60s full exhaust etc etc and i get no wheel hop so i highly doubt its the mounts or the car.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
