Tune!!!
Tune!!!
I called a shop here in Toronto to get a tune since im running lean. I installed a xtc downpipe w/hi flow cat,KN typhoon CAI, and a magnaflow cat back. The guy say's he can get me maybe 20 hp from a tune alone? Does this sound right, and can he increase my boost with the tune to 11-12 psi? He said i will need about 6-10 runs on the dyno, and will be using HP tuners. Sound right, or BS!?
12? Im only pushing 8 psi? WTF is happening to my car? Are u sure, cause someone told me they run on 8psi, but can be brought to 12psi safely, before needing to change injectors and crap?
the max boost on a stock pulley is 12.5 psi like he said. Doesn't mean you'll hit it all the time. It just depends on your location and a couple other factors.
If you really want more boost, get a smaller pulley and bigger injectors. That'll give you a good increase out of a tune.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/lsj-boost-issue-fixes-221299/
might help you out. a lot of people are having boost issues it seems
and please delete your other thread aha
