Tune help VE LTFT scan -50?
Help! I've searched all over the forums and HPT and I'm learning how to tune but I'm getting scans on my LTFT that are around -50. I just installed a 3" zzp longtube, catted downpipe, res, and 3" catback (all zzp) and I have an AEM intake. Does anyone have this setup that has a scan file or HPT config file so I can compare? Just installed a wideband today but cant log with HPT since I dont have pro. I haven't changed any tables yet just took off TQMGMT dropped boost in 1st and disabled a/c after 5000rpm and wot.
2006 Cobalt ss/sc.
2006 Cobalt ss/sc.
Post your tune, config and a log. You may just have your PID's or histogram set incorrectly, but it is hard to know with nothing to go off of.
I assume since you are referencing VE, you have your MAF disabled. Engine Diag > Airflow > MAF Fail High set to 0Hz.
Did you dissable CFCO, DFCO and COT?
I disable LTFT's and tune with STFT's after I have dialed in my Stoich. What did you set your Stoich to?
Haven't tuned anything yet. Stoich left alone. Disabled all but cqt. I'm catted should I disable it? Tune is stock as far as fuel/timing etc... I'm on the road going outta state scan was worrying me seems like I'm rich?
14 - 15.5 cruising is fine for now.
yeah, the setup that the software comes up with is incorrect. at least for tuning the lsj.. well not incorrect, just not very usefull
its gonna take a bit of reading before you even get your config setup how youd like it to be to properly tune. id send you mine, but it wouldnt help as i have mine setup for an ngk wideband and all the custom pids would get alittle confusing.
thanks for the replies. had a hell of a week with work, my phone, laptop and tv all crashed and I'm still stuck on 12 hr shifts 6 days a week... ehhh... but hopefully soon I'll do some more reading and reconfigure the software to read correctly and go from there. again thanks for the input. I'll need more soon, I'm sure of it.
