Turbo???
Old Mar 22, 2006 | 06:02 AM
cavy9psi's Avatar
Turbo???
im new to the SS supercharged, im looking to sell my 99 turbo Z and buy a SS S/C. heres what i want to know...has anyone thought about a turbo conversion. cuz what does the cobalt put for stock boost 10psi? im no where near sure but put a decent sized turbo at the same you will def make more power. and the computer is already designed for boost so its not a question of how hard would a tune be and what not..im just thinkin i want a lot of power....and im not knocking the intense package thats amazing but i came across a few posts that mentioned KNOCK...and the response was its fine its not a lot....KNOCK is no where near good my only thought would be maybe if you go with the REFLASH when the gm kits do come out it could upgrade it enough to lose the knock also running 93...i have to run 93 in my turbo cav cuz i get preignition like a mother with out it...87 my car "knocks" llike crazy...just wanted some info basically like i said im big on turbo's i do a lot of turbo set ups with friends cars, so this whole supercharger thing just crossed my mind. thanks
Old Mar 22, 2006 | 10:44 AM
celicacobalt's Avatar
it would be a good idea, i think gm realized that now and they using a 2.0 turbo in the new cars
Old Mar 22, 2006 | 01:29 PM
cavy9psi's Avatar
when you say turbo on the new cars which ones and when? cuz ill wait to buy an SS till they get a turbo SS not an S/C...
Old Mar 22, 2006 | 02:22 PM
NoRemorse's Avatar
Doubt it will be in a cobalt. Think Pontiac Soltice GXP.
Old Mar 22, 2006 | 02:40 PM
retrop's Avatar
The set-up has been thought about with parts from the 2.0 turbo Saab's but no-one has tried it yet to my knowledge. I'm sure once tuning becomes possible more people will be willing to try it out. I think the 2.2 and 2.4 platforms would be better if you want to go turbo though personally. I would rather see a supercharger upgrade cause i love the always there power. This car was designed for corners more than a straightline so the turbo has its drawbacks there.
Old Mar 22, 2006 | 02:44 PM
mi6_'s Avatar
2.0L turbo from the Solstice does not fit in the Delta platforms engine bay when transversley mounted. There is not enough room for the dual-scroll turbo to mount in the manner it does in a RWD application. That is why Pontiac chose to use this engine instead of just the LSJ.
If they ever turbo the Cobalt, it would at least have to be a differen't turbo.
Old Mar 22, 2006 | 09:35 PM
cavy9psi's Avatar
so i was reading a write up in hot rod magazine, december 05 issue (yea im alittle behind) its an SS S/C write up... they mentioned a $1,500 upgrade of Quife LSD and Recaro seats is that true??? also they had a part about how the STAGE II upgrade for it was impressive...so i bet everyone cannot wait...i can't either...
Old Mar 22, 2006 | 09:41 PM
NoRemorse's Avatar
I have a redline and that option is called the compitition package. I think its called the G85 option on the cobalt though
Old Mar 22, 2006 | 09:47 PM
MarcS's Avatar
The Stig
You can do what the Wbody has been doing. Unbolt the blower snout and remove the rotors. Place a cutoff plate where the snout used to be. You would now have an intake plenum (sc housing) which will allow you to use the stock intercooler and tb position.
Old Mar 22, 2006 | 10:18 PM
ajent's Avatar
$1500+tax for G85 +install? or is there a labor price added also?
Old Mar 22, 2006 | 11:41 PM
ReMz's Avatar
its a dealer option from the factory
Old Mar 23, 2006 | 12:51 AM
theBLUEone's Avatar
I have the Intense kit and it is worth every penny... And if you have the settings correct with a safe a/f WOT then you should not have knock at all....I actually have not experience any knock at all. The most I have see was .3, but I was going uphill and I did not downshift...But thats with any car....
Old Mar 23, 2006 | 07:25 AM
ajent's Avatar
Yeah, I know. But I'm not sure how they charge when you go there for things and pay for it.
Only time i've gone there is stuff under warrenty.
Old Mar 23, 2006 | 10:12 AM
9JordonFlex9's Avatar
I wish i knew more bout superchargers...bah...but anywho
what bout the hahn 2.0 SC model they working on? Turbo working with the Supercharger.....
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
