Turbo choices...
I have seen people with your turbo do 440 whp and only have 330 tq. Same difference
Ok well I just realized you said stock motor. Cylinder pressure on 25psi on stock motor may spell disaster.
found some interesting info on garrett's website today comparing the gt2086rs, gt3076r, gt3582r and the gt3071r installed on a 2.0L motor:
http://www.turbobygarrett.com/turbob...o_tech103.html
We now have enough information to plot these operating points on the compressor map. First we will try a GT2860RS. This turbo has a 60mm, 60 trim compressor wheel.
Clearly this compressor is too small, as both points are positioned far to the right and beyond the compressors choke line.
Another potential candidate might be the GT3076R. This turbo has a 76mm, 56 trim compressor wheel:
This is much better; at least both points are on the map! Lets look at each point in more detail.
For the 2.0L engine this point is in a very efficient area of the map, but since it is in the center of the map, there would be a concern that at a lower engine speeds that it would be near or over the surge line. This might be ok for a high-rpm-biased powerband that might be used on a racing application, but a street application would be better served by a different compressor.
For the 5.0L engine, this looks like a very good street-biased powerband, with the lower engine speeds passing through the highest efficiency zone on the map, and plenty of margin to stay clear of surge. One area of concern would be turbo overspeed when revving the engine past peak power. A larger compressor would place the operating point nearer to the center of the map and would give some additional benefit to a high-rpm-biased powerband. Well look at a larger compressor for the 5.0L after we figure out a good street match for the 2.0L engine.
So now lets look at a GT3071R, which uses a 71mm, 56 trim compressor wheel.
For the 2.0L engine, this is a much more mid-range-oriented compressor. The operating point is shifted a bit towards the choke side of the map and this provides additional surge margin. The lower engine speeds will now pass through the higher efficiency zones and give excellent performance and response.
For the 5.0L engine, the compressor is clearly too small and would not be considered.
Now that we have arrived at an acceptable compressor for the 2.0L engine, lets calculate a lower rpm point to put on the map to better get a feel for what the engine operating line will look like. We can calculate this using the following formula:
Well choose the engine speed at which we would expect to see peak torque, based on experience or an educated guess. In this case well choose 5000rpm.
Where:
ˇ Wa = Airflowactual (lb/min)
ˇ MAP = Manifold Absolute Pressure (psia) =41.1 psia
ˇ R = Gas Constant = 639.6
ˇ Tm = Intake Manifold Temperature (degrees F) =130
ˇ VE = Volumetric Efficiency = 0.98
ˇ N = Engine speed (RPM) = 5000rpm
ˇ Vd = engine displacement (Cubic Inches, convert from liters to CI by multiplying by 61, ex. 2.0 liters * 61 = 122 CI)
= 32.5 lb/min
Plotting this on the GT3071R compressor map gives the following operating points.
This gives a good representation of the operating line at that boost level, which is well suited to this map. At engine speeds lower than 5000rpm the boost pressure will be lower, and the pressure ratio would be lower, to keep the compressor out of surge.
Where:
= 32.5 lb/min
for sure you will have to crank the 28 up a fair bit to get the numbers you want. Also 360 is just a random number it might feel like a freight train to you and be around 320whp and traction becomes a serious issue
I just want to get the car over 350 and close to 400. Kind of a personal goal I had before I even bought the car and was doing research on it and it's possible power upgrades.
But I can see him getting the 30r and accomplishing 360WHP with only 260-280tq.. With the 28r he can wick the turbo up and gain some decent tq numbers out of that turbo and get to his HP goal.
I'd rather have that little bit of room if I want to turn it up. But, regardless they are both considerably better than the 28.
forgot where i seen it at, i'll try to find a link
I would think that a 90 trim turbine wouldn't even spool til like 4500 rpm...but then again I'm still learning the ins and outs of turbos here
Anyone else have opinions? Or possible other options?
http://www.youtube.com/user/black06g.../7/yuzbc1WCSmI
3076R. Dont know all the supporting mods on the car but it sure sounds nice.
Mods:
11.5ish afr @ about 16-17 degrees timing
91 pump gas
7gph meth jet
GT2871 @ 15lbs creepin to 18lbs by 7000rpm
Hahn intake mani
60lb injectors in return system
3" exh from turbo back.
16PSI 361whp at 6810rpm, 290.1wtq @ 6000rpm
91 pump gas
7gph meth jet
Hahn intake mani
You can ask Tom about it feels... he tunes it.
There is a member of this board that made 360whp with 16psi on a GT2871R
I've got a S256ET for sale @ $800... and I'm about to sell pretty much my entire set-up for $1500 (Minus the BOV and the Intake Manifold). You'd just need those two things plus figure out how you wanna run your Alternator set-up. My set-up would be good if you are looking for upper 300's/low 400's whp.
I would say its a good tune. There is a Dynojet and a Mustang dyno around him, both within 3whp of each other, iirc. As others have said about it, its amazing what happens when the right compressor is paired with the right displacement and anticipated PR.
