Turbo fitting Question!!!!
I have the S20g turbo kit from Hahn and I am wondering if anyone knows, because I cant find it anywhere, if on the oil feed line the fitting that goes onto the turbo inlet for the oil if it is supposed to be -4 fitting? Im having trouble figuring out why my car is burning oil. It could be plenty of things since it was rebuilt, but I wont get into that. I have been told that the S20g turbo should have a restriction for the oil inlet into the turbo and the fitting should be a .065 fitting or somewhere around there to restrict the oil going in so it doesnt back up in there and blow the seals. Also to be known it does seem ans the seal might be blown as there is some shaft play on the turbo. Any input would be great, thanks.
Has anyone talked to hahn about that issue and see if there could be some kind of refund for that setup since it was an issue and was not working correctly?
