turbo lsj issues, breaking up
Since I've turbo'd the car I've had the same problem. At high RPM at high boost the car will fall flat on its face.
I've been through 2 different turbos, 2 different wastegates, 2 intake manifolds and converted from draw through to blow through. I thought all of these things would cure it but it still happens.
When I scan it, I get no knock, my boost levels stay even and my AFR stays right on. So before I put idea in everyone's head as to what I think it is I want to see what you guys are thinking.
The problem happens at about 6k at 18psi and lower RPM's for higher boost, and not at all at lower boost.
I need some suggestions. Give me some info throw those ideas out guys.
I have logs but you can't see that there is even a problem on them.
Why would I be the only one with that problem? Is this something I should know about?
I always thought compressor surge was audible and this is my second turbo so I figured that would eliminate it. Anything is possible now though.
They are i normal operating range.
Injectors are at about 85%
This is what I think the problem is. I'm using a NGK BKR7E copper plug gapped to .28 right now. I recently changed them after the new setup was done, they probly have around 500 miles on them now.
I guess I can try gapping them to .24 and see if that helps the issue at all. I thought .28 was about as small as I should go with them.
Maybe I need a colder plug, what do you suggest???
I multiplied dwell vs rpm vs volts by 1.1 where it happens, I'll give that a try. Is that what I should be playing with?
I went %110 and then %110 on top of that and it didn't make a hint of difference. It seems to happen right at 6k. IDK what to do now I thought I finally had a fix to the issue.
I'm going to try and drop the gap to .24 I think and see if that does anything.
this has happened to me before, spark blow out, not really feel it too bad but can feel it miss and you can hear it shooting ducks out back... only at boost levels of 18 or more which is odd caus thats what your describing.
wb confirms its not lean, hpt shows no kr. idc is at 68-74% w/meth. plugs are at .026 bkr7e.
honestly i just stay in it and it will stop. only does it when its cold and thick outside, and only misses once or twice then clears up...
i chalked it up to spark blow-out, and keep my foot in it
but i am looking for a fix as well!
Last edited by hungryhip-ccp; Mar 26, 2009 at 12:27 AM. Reason: Automerged Doublepost
