turbo lsj issues, breaking up
Old Mar 22, 2009 | 08:45 PM
Maxim_X's Avatar
Exclamation turbo lsj issues, breaking up
Since I've turbo'd the car I've had the same problem. At high RPM at high boost the car will fall flat on its face.
I've been through 2 different turbos, 2 different wastegates, 2 intake manifolds and converted from draw through to blow through. I thought all of these things would cure it but it still happens.
When I scan it, I get no knock, my boost levels stay even and my AFR stays right on. So before I put idea in everyone's head as to what I think it is I want to see what you guys are thinking.
The problem happens at about 6k at 18psi and lower RPM's for higher boost, and not at all at lower boost.
I need some suggestions. Give me some info throw those ideas out guys.
I have logs but you can't see that there is even a problem on them.
Old Mar 22, 2009 | 08:57 PM
SS/SCking's Avatar
Ported head?
Old Mar 22, 2009 | 09:02 PM
Maxim_X's Avatar
No it's the stock head.
Old Mar 22, 2009 | 09:27 PM
SS/SCking's Avatar
might be your problem..
Old Mar 22, 2009 | 11:06 PM
OntarioKev's Avatar
How much timing when the problem happens, and is there any change (up or down) in the timing right before/after the problem?
Kevin
Old Mar 22, 2009 | 11:18 PM
Maxim_X's Avatar
Kevin
No it's linear through the issue.
Why would I be the only one with that problem? Is this something I should know about?
Old Mar 22, 2009 | 11:31 PM
OntarioKev's Avatar
MAF and MAP voltages when the trouble starts?
Kevin
Old Mar 22, 2009 | 11:35 PM
BoostedYards86's Avatar
compressor surge?... more boost than can be used coming back to the turbine, just a thought. Buddy had the problem on his Evo
Old Mar 22, 2009 | 11:36 PM
Sunburst_SS's Avatar
plugs? gap? possible spark blow out?
Old Mar 22, 2009 | 11:44 PM
Ryze's Avatar
I'd guess that also, or your maxing out your injectors, but you should be able to see that via afr's
Matt M's Avatar
Plug gap would be my guess. What plugs are you running and how much gap? Try new plugs and close the gap .010" tighter and see how it runs.
Old Mar 23, 2009 | 12:25 AM
Area47's Avatar
Rent me! per hour
drop the plug gap to .028
from what you described. you're blowing the spark out.
Old Mar 23, 2009 | 04:37 AM
Maxim_X's Avatar
I always thought compressor surge was audible and this is my second turbo so I figured that would eliminate it. Anything is possible now though.
Kevin
They are i normal operating range.
Injectors are at about 85%
This is what I think the problem is. I'm using a NGK BKR7E copper plug gapped to .28 right now. I recently changed them after the new setup was done, they probly have around 500 miles on them now.
I guess I can try gapping them to .24 and see if that helps the issue at all. I thought .28 was about as small as I should go with them.
Maybe I need a colder plug, what do you suggest???
Old Mar 23, 2009 | 03:55 PM
Area47's Avatar
Rent me! per hour
the plugs are fine. you may have to up the dwell time on the coils a touch to get it to work right
Old Mar 23, 2009 | 04:34 PM
Maxim_X's Avatar
What table should I adjust it with? I've never touched that before.
I multiplied dwell vs rpm vs volts by 1.1 where it happens, I'll give that a try. Is that what I should be playing with?
Old Mar 23, 2009 | 04:45 PM
Area47's Avatar
Rent me! per hour
base dwell time
don't get crazy with it. it will fry the coils.
Old Mar 23, 2009 | 06:12 PM
Maxim_X's Avatar
Is that extra 10% excessive?
Old Mar 23, 2009 | 07:20 PM
Area47's Avatar
Rent me! per hour
thats fine in a voltage area and rpm area. leave the lower side below 5500 alone. from 5550-8k turn it up a smidge
Old Mar 23, 2009 | 08:35 PM
Maxim_X's Avatar
How did you learn all this info? Thanks for the great help! I appreciate it.
Old Mar 23, 2009 | 09:42 PM
Area47's Avatar
Rent me! per hour
trial and error mostly
and help from a group of 733t friends
lol
Old Mar 25, 2009 | 08:49 PM
Maxim_X's Avatar
I went %110 and then %110 on top of that and it didn't make a hint of difference. It seems to happen right at 6k. IDK what to do now I thought I finally had a fix to the issue.
I'm going to try and drop the gap to .24 I think and see if that does anything.
Old Mar 25, 2009 | 09:10 PM
watching. hope everything works out for you!
Old Mar 25, 2009 | 10:29 PM
Maxim_X's Avatar
Someone has to know whats wrong. I can't be the only car with this problem. I will pay to get a fix.
Old Mar 25, 2009 | 11:57 PM
Area47's Avatar
Rent me! per hour
like a complete studder issue? or a sudden drop in rpm then it picks back up?
Old Mar 26, 2009 | 12:27 AM
hungryhip-ccp's Avatar
this has happened to me before, spark blow out, not really feel it too bad but can feel it miss and you can hear it shooting ducks out back... only at boost levels of 18 or more which is odd caus thats what your describing.
wb confirms its not lean, hpt shows no kr. idc is at 68-74% w/meth. plugs are at .026 bkr7e.
honestly i just stay in it and it will stop. only does it when its cold and thick outside, and only misses once or twice then clears up...
i chalked it up to spark blow-out, and keep my foot in it
but i am looking for a fix as well!
Last edited by hungryhip-ccp; Mar 26, 2009 at 12:27 AM. Reason: Automerged Doublepost
