Turbo size
I like it.
And you should switch to a Hallman Pro Boost Controller. They are ACE!
so i got one of those hallman pro rx iirc...
question on that though, for the light spring and ceramic ball it says approx. 5 psi over stock. that is referring to whatever the wastegate is set on + 5 psi? or is it better to just use the stiffer spring?
yeah in another thread i posted up how i liked that turbonetics replica but right before i left for DC it kept jumping around on boost levels. one second it was 16 one second it was 24 and you just never knew what it was going to hit. first few days it worked fine
I run the Hallman Pro. I like it. I've added 12psi over wastegate with it so far. My new wastegate has a 15psi spring, so I won't have to add so much.
You can't really overdo what the wastegate is designed for... unless you are trying to dump too much exhaust through too small of a wastegate, but you won't have that problem.
The only thing you need to worry about if you were to ever order a different wastegate, is getting too high of a spring. With a turbo wastegate, you order it with a set spring.
For example... my new Tial has a 1bar (14.5psi) spring in it. I can run nothing lower than 14.5psi. I can, however, add a Boost Controller and run MORE boost. So if you order a wastegate with a 20psi spring... that'll be the lowest amount of boost that you can run.
I hope that I explained that in a way that someone else can comprehend.
yes... so saying your boost controller ALL the way down is a MIN of 14.5 PSI.... turning the controller UP will cause it to make...... PSI. since your making 14.5psi isnt the wastegate staying open when ever it goes above 8ps?
Yeah, with the Pro RX, that'll be Wastegate pressure + up to 5 more PSI. So if your wastegate spring is a 15psi spring... you can adjust between 15psi and 20psi.
If I take the boost controller off or turn the boost controller all the way down... the car will only make 8psi. So, when I punch it... the turbo hits 8psi and the wastegate opens up and dumps exhaust PRE-TURBO so that it can maintain the boost level at 8psi. If I crank the boost controller, like I have, what happens is you are, in a way, hiding the boost from the wastegate. So the turbo is actually hitting 22psi, but the wastegate is only seeing it as 8psi, because the Boost Controller is essentially hiding the boost from the wastegate. In this scenario, the wastegate stays closed until I get up around 22psi, and then it opens and dumps exhaust pre-turbo in an effort to maintain 22psi.
I'm betting that the only difference will be that 1 full turn on an RX will be like 1psi of boost... where as 1 full turn on the Pro is like 2-3psi.
Last edited by USMCFieldMP; May 13, 2010 at 06:04 PM. Reason: Automerged Doublepost
The current Wastegate that's on the car has a 8psi spring, meaning that I can run NO LESS than 8psi. Once the new Tial wastegate goes on the car, THEN my minimum will be 14.5psi.
I can add more boost with a boost controller... but I can't take boost away from the Wastegate Springs Base.
You have the 5031E or the 5031R? E is journal bearing... R is Ball Bearing.
You should dyno it and lemme know your results.
I'm too lazy to go dyno mine.[/QUOTE]
i have the 5031E journal bearing. and i will dyno it when i get my clutch done and the tune finished.
the hallman pro rx with the light spring only runs up to 17.5 psi on my car so no one worry about buying that kit. save your $ and get the non-rx
i'm installing the heavier spring now to resolve those issues
