turbo swap
turbo swap
so i am using zzp to trubo swap in my lsj, i got everything only thing im left in the dark about is will my stck fuel pump hold up?? where do i tap the oil feed and return?? and who can i get a good tune from p or trifecta?? i need atleast the base map so it will start haha
You need software to flash or you need someone with the software to use credits to unlock your pcm to flash, the reason I mentioned zzp is because for a price they will email you an hptuners file and you can work from that
ThoR294
Oct 4, 2015 08:44 PM
