Turbo Swap ?'s
u keep ur throttle body , injectors if the ones u have are gonna work wit ur set up and thats about it. sc u sell intake mani u sell, header and dp from sc set up u sell, u need to change the pulley tentioner take off the iddler pulley and get a 2.2 one. u can use yous stock alt if u get it welded if not get a 2.2 alt. also ur sc belt u sell and u need 2.2 alt bolts
some questions while i was taking things apart.
first do i need to remove the selonid that controls the stock supercharger bypass valve circled in green
also i was looking at the head and mounted up my intake manifold. it doesnt cover the hole in green and dont know what its for
You can keep your Stock IM and your M62. ZZP makes a rotor delete plate for turbo charged LSJs. They don't have it listed on their site yet but I am sure they will sell you one if you contact them.
http://www.zzperformance.com/cobalt_...=934&catid=143
Then there is no need for a new IM, idler pulley, or adapter plate.
ThoR294
Oct 4, 2015 08:44 PM
