tvs 2.7 pulley issue
Old Apr 11, 2011 | 10:24 PM
cli3e0339384398jk's Avatar
im running a 2.7 on the tvs with 7 gph meth nozzle, i used to be able to run 22-23 timing into it on top end before i did an engine rebuild, now im knocking at 19, ive knocked it all the way down to 18 which is way to low for meth, the only other thing i can think is i got a bad tank of gas. What ar others able to run for top end timing with a 2.7 pulley on the tvs.
whats also weird is i can do a 2nd gear pull and it will not knock, then do a 3rd gear and same cells detect knock
Old Apr 11, 2011 | 10:32 PM
WickedSS2005's Avatar
I was pulling 25* and running E85. Most cars I know can hold 23-24 easy on any setup with methanol or E85
Old Apr 11, 2011 | 10:37 PM
Chevycobaltss3's Avatar
Bad tank of gas, iat2s or tune is ****
Old Apr 11, 2011 | 10:55 PM
Yah I'm really thinking it was bad gas as I hadno issues before and my maf is dialed in and timing map is smooth as it gets, unless I got crap methanol it is the bottom of my last jug. Iat 2 are low as well
Old Apr 11, 2011 | 10:59 PM
Yeah could be the meth or gas. .. Hopefuly its not a ringland if it dont go away by the fill up after next and same with meth do a compression test
Old Apr 11, 2011 | 11:22 PM
brand new pistons, and i just did a compression test to verify and got good compression
Old Apr 11, 2011 | 11:57 PM
InfraRedline's Avatar
Did you check to make sure the meth pump is operating at full pressure?
Old Apr 12, 2011 | 12:06 AM
Yah I thought of that today and did a check and I'm getting good flow and spray
Old Apr 12, 2011 | 09:14 AM
alleycat58's Avatar
Only 22-23*? I've got 28* on a 2.7 and E85, no meth.
I was going to suggest checking the meth, make sure it's working. Since you said it was, I'd wait it out for a tank or two and see what happens.
Old Apr 12, 2011 | 11:05 PM
yah, its pissing me off, ive posted tune and log on hp tuners forum if people want to take a look, upper maf is not dialed in but is hard when it keeps knocking when trying to dial it in
Old Apr 12, 2011 | 11:22 PM
ebristol's Avatar
I love posts like this!
Are you running the same CR on your new pistons?
Old Apr 12, 2011 | 11:51 PM
RooTBeeR's Avatar
it would think that it would knock in 3rd more than 2nd because its putting more load on the engine
this
Old Apr 12, 2011 | 11:57 PM
yes, but i bought them from someone else that said they ordered 9-5 cr(brand new never installed), if they were 10-1 that would explain the issues
this
yah thats what i figured as well but with 100 %meth and knock at 6400rpm when it only calling for 18 timing it doestn make sense
Last edited by cli3e0339384398jk; Apr 12, 2011 at 11:57 PM. Reason: Automerged Doublepost
Oct 20, 2015 09:56 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
