tvs boost drop
Old Nov 12, 2012 | 08:04 PM
advise's Avatar
tvs boost drop
Did a 3rd gear pull and at around 5k it drops from 24 to 15psi
Did this 3 times
Just changed the belt
would the bypass just open mid pull or belt slip?
Old Nov 12, 2012 | 08:07 PM
TStone's Avatar
Belt slip could be possible, but it wouldn't cause that big of an decrease in boost.
Your bypass valve could possibly be messed up. That's kinda what it sounds like to me
Old Nov 12, 2012 | 08:11 PM
advise's Avatar
Ya and it's a smooth 15 psi
Not fluttering like belt slip would
Old Nov 12, 2012 | 08:13 PM
TStone's Avatar
Ima say bypass valve then
Old Nov 12, 2012 | 08:18 PM
advise's Avatar
Any way to test it?
Old Nov 12, 2012 | 08:23 PM
TStone's Avatar
See if there's any play in it.. other than that, no not really
There should be very minimal play at max
and by "it", I mean the metal shaft/rod
Edit: Ah yes, forgot about that VVVVV
You can plug the port coming off the bypass solenoid and the one coming off the bypass valve and see if it fixes your issue
Old Nov 12, 2012 | 08:25 PM
Powell Race Parts's Avatar
pull the hose off the bypass and do a run.
Old Nov 12, 2012 | 08:27 PM
by pass valve shafts can seize especially if meth has been put through the blower. In my experience they seize open. If you have a vacuum leak at the IM, the valve will open and close at idle and generally misbehave... if you pull the hose, just stick a plug in it, the valve dont care, the solenoid does and you dont want a vacuum leak there.
Old Nov 12, 2012 | 09:09 PM
advise's Avatar
Did a run works fine If it happens connected pull the hose on the valve
As for the shaft being stuck i can actuate the valve by hand no problem
My idle has been surging but i believe it's do to the winter blend e85
All my vaccum lines look fine and connected
Old Nov 12, 2012 | 11:11 PM
TStone's Avatar
You should be able to actuate it.. But you shouldn't be able to move it back & forth & round and round. Kinda hard to explain the motion
Old Nov 14, 2012 | 03:18 PM
advise's Avatar
Moved it around seemed good
Did 2 pulls no problem
Hope it doesn't happen again
Only a week or two before she gets garaged for
A little winter build cams springs balancing shafts and 1000s maybe a ported head
Old Nov 14, 2012 | 07:31 PM
574's Avatar
574
What cams are you going with?
Old Nov 14, 2012 | 08:47 PM
advise's Avatar
zzp stage 2
Old Nov 14, 2012 | 09:06 PM
574's Avatar
574
Nice, I'll be waiting for a review on those lol
Old Nov 15, 2012 | 01:15 PM
advise's Avatar
Still.the same problem what hose am i removing
Old Nov 15, 2012 | 01:34 PM
rivaladore's Avatar
The hose that goes to the bypass valve. Take the hose off right there but leave it attached to the solenoid which is to the right of the valve cover. Plug the hose don't worry about plugging the bypass valve nipple. You plug the hose so there's not a vacuum leak at the bypass solenoid.
Old Nov 15, 2012 | 01:52 PM
advise's Avatar
Gotcha and if I have no boost loss my valves bad
Old Nov 15, 2012 | 04:02 PM
Area47's Avatar
Rent me! per hour
belt slip. get a larger tensioner.
Old Nov 15, 2012 | 05:19 PM
advise's Avatar
I have a larger tens. And a phenolic spacer
And it seems a little odd that i had the same pulley
Size (2.7) on my m62 for 2 years no issue and out the blue this happens
Old Nov 15, 2012 | 05:24 PM
Area47's Avatar
Rent me! per hour
weak tensioner then.
Old Nov 15, 2012 | 07:15 PM
advise's Avatar
changed my belt from a dayco i got from work to my original gm belt
problems fixed 25psi all day
Old Nov 15, 2012 | 07:37 PM
^^^ u said it was not the belt like 200 posts before...well. glad u got it fixed. lol
turbochargedss2012
Sep 20, 2023 12:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
grampss
Sep 27, 2015 08:51 PM
