TVS experimenting again
Old Aug 27, 2008 | 11:12 AM
Omega_5's Avatar
True... but it goes goes to show that the blower will loose efficiency after stacking on that much pressure.
Don't get me wrong... I have plans to get one... but I have noticed some people spouting words of high efficiency at high boost.
You have probably seen the extrapolated chart that I sent to LSJwannabe... I think this fits that model pretty close.
Area47's Avatar
Rent me! per hour
dropping timing 5-6 degree's across the board, and still getting slight knock up top, not my idea of fun. torque steer half way through third is amusing.
Old Aug 27, 2008 | 11:20 AM
Josh@ottp's Avatar
The lower pulleys need more meth too. You run a 75/25 mix? What size nozzle?
Old Aug 27, 2008 | 11:25 AM
Area47's Avatar
Rent me! per hour
90/10 mix. 5gph nozzle.
Old Aug 27, 2008 | 11:39 AM
Josh@ottp's Avatar
We had to bump seans car up to a 7gph.
Old Aug 27, 2008 | 11:49 AM
Area47's Avatar
Rent me! per hour
how much timing was he trying to run?
Old Aug 27, 2008 | 11:50 AM
badasscobalt1986's Avatar
where and how much did you pay for your tvs blower?
Old Aug 27, 2008 | 11:54 AM
Area47's Avatar
Rent me! per hour
i bought mine used from someone in michigan. new they are 2250 i think. somewhere around there.
web site for harrop
http://www.harrop.com.au/
Old Aug 27, 2008 | 11:57 AM
Witt's Avatar
Originally Posted by Area47
witt. i had to find out for myself.
Ah the days of having retarded EGTs and a slow car.
Old Aug 27, 2008 | 11:59 AM
lsjwannabe's Avatar
i ran 21* on pump gas with the 2.75" and a 30/70 mix. When i pullied down i had to pull out 5* go up to the 7gph and go with 2step colder plugs.
Old Aug 27, 2008 | 12:38 PM
  #36
Area47's Avatar
Rent me! per hour
your motor lived due to the pistons in it.
my egt's last night hit 1500 at the top of third. i didn't do that **** again.
sean. i was a bit lower than that on 7's. not much lower, but a bit
you still have that 7? nate still hasn't checked his pm's on here.......
Old Aug 27, 2008 | 12:40 PM
  #37
lsjwannabe's Avatar
yeah still tapped in the intake
Old Aug 27, 2008 | 12:44 PM
  #38
Area47's Avatar
Rent me! per hour
hmmm. i'll do some iat and idc experiementing before i go up in gph sizes.
NATE CHECK YO PM'S FOO!
Old Aug 27, 2008 | 01:04 PM
  #39
Kennyspec's Avatar
sometimes i wonder if the cobalts need bigger meth jets as the meth needs to go through the shitty lamenuovas (sp?). I wonder how much of it is just puddled at the bottom of the manifold????
Old Aug 27, 2008 | 01:46 PM
  #40
Josh@ottp's Avatar
according to my calculations he should be running a 7gph. I doubt any of it is puddled, that would be very hard to achieve.
Old Aug 27, 2008 | 06:17 PM
  #41
EatonTVS07's Avatar
area did you fix your lifter issue you had?
SmitBag
Sep 7, 2016 08:05 AM
Silverbullet333
Oct 4, 2015 02:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
RedLined
Sep 9, 2015 09:11 PM
