tvs install issues
Old Jun 14, 2013 | 11:07 PM
skeeter123's Avatar
tvs install issues
I installed a tvs, dual pass with option b and phenolic spacer. I am getting it tuned from Trifecta via Bad news racing. I just received a response from them after sending them data logs:
Looks like there is an intake leak. Were seeing higher manifold pressure at idle than we should, idle is pulsating, and trims are very positive.
You're going to need to double check the install (possibly make sure the supercharger is sitting flush on the intake manifold).
My question is how do i find this leak. I have taken the supercharger off a few times already because of leaks coming from the dual pass. I have not had any issues putting the tvs back on everything seems good. Any ideas or comments?
Old Jun 14, 2013 | 11:12 PM
Melon's Avatar
Spray brake cleaner at random spots from intake to intake manifold and u will hear the engine bog down when u hit the leak
Old Jun 14, 2013 | 11:24 PM
Beck's Avatar
what he said
Old Jun 14, 2013 | 11:27 PM
Powell Race Parts's Avatar
Try this: take the phenolic spacer off. If you installed it with one OEM steel and one composite gasket it will leak. The spacer needs a composite gasket each side. BTW I have had no positive success with the phenolic spacer on my TVS .
my .02 c
Old Jun 14, 2013 | 11:35 PM
mrbelvedere's Avatar
the phenolic did not do **** for me the only way you will have a vac leak is if you did not put the green bypass gasket on or what mr powell has mentioned
Old Jun 14, 2013 | 11:53 PM
Melon's Avatar
That's wut I keep hearing that the phenolic is nothing but hassle
Old Jun 15, 2013 | 02:58 AM
Bluelightning's Avatar
Got Bewst?
Depends who you talk to
Old Jun 15, 2013 | 08:21 AM
skeeter123's Avatar
Ok guys took the tvs off and put back on my idle issues are now gone, I did the brake cleaner trick and did not find any leaks, going to send trifecta another set of data logs.
Old Jun 15, 2013 | 12:51 PM
06cobalt racer's Avatar
off topic but did vince charge you more when u put the tvs on?
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
