tvs installation
Old Apr 18, 2011 | 12:56 PM
Cobalt_Newb's Avatar
tvs installation
I'm installing a tvs supercharger, just wondering if anyone else ran into problems with the bolts and how they ended up getting them on (special tools), especially for the 2 that are at the front. As well as the MAP sensor. I had to unsrew it to allow for the supercharger, did anyone modify it so that they could screw it back in?
Old Apr 18, 2011 | 01:03 PM
Pyros777's Avatar
You need to cut away part of the map sensor and rotate it out of the way. The TVS itself will hold it in place.
I don't have a picture of mine, but you should end up with something like this:
(thx rootbeer)
I used short head hex keys to tighten the front bolts on.
Amazon.com: Lisle 42850 Short Head Fractional Hex Key Set: Automotive Amazon.com: Lisle 42850 Short Head Fractional Hex Key Set: Automotive
edit: just in case you strip one and need to replace it, the bolts are M8 x 1.25 x 40mm
Old Apr 18, 2011 | 01:08 PM
Thanks dude I'll head out to the store to find some.
Old Apr 18, 2011 | 02:29 PM
InfraRedline's Avatar
I agree with Pyros, same way I did mine
Old Apr 20, 2011 | 06:15 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
subd for bolt size
Old Apr 20, 2011 | 01:19 PM
TurboTommy's Avatar
sub'd
Old Apr 20, 2011 | 01:26 PM
SSmokie the bear's Avatar
putting mine on tomorrow. I am glad I saw this 1st!! Anymore issues I might run into?
Old Apr 20, 2011 | 02:28 PM
Just make sure the injector clips arent angled towards the mounting point on the blower. I dodnt remember if that was a problem on my 80's or not but my 98's rested against the blower and leaked, so I had to rotate the injector in the rail a bit.
Old Apr 20, 2011 | 02:50 PM
Tennpenn83's Avatar
i ended up changing the bolts for regular six-sided head bolts. has a 10mm socket sized head that is far easier than using an allen key or something. use that, plus a u-joint and an extension and you'll be fine
Old Apr 20, 2011 | 02:59 PM
WTF!?!?! There are 98's?! I thought the biggest were 80's and that why I got them
Old Apr 20, 2011 | 03:07 PM
RoadconeTuning's Avatar
Injector Dynamics makes a 1000cc and 2000cc injector too... there are 160lb injectors that are "cheap" too
Old Apr 20, 2011 | 03:18 PM
RooTBeeR's Avatar
[img]https://i151.photobucket.com/albums/s125/slobalt123/168d gg1.jpg[/i mg]
(thx rootbeer)
lol thats not my pic, one i found on here and posted, i drilled out the hole on mine to a slot so i could still bolt id down.
and a 6mm(iirc) ball end Allen wrench is what i used to get those botls in and they are a pita no matter what lol jsut takes time to do it thats all
Old Apr 20, 2011 | 05:18 PM
Pyros777's Avatar
oops just figured it was yours
yeah 6mm. I ended up stripping most of a stock bolt using a ball end though. lol
short head hex ftw
Old Apr 20, 2011 | 05:45 PM
I also see the bpv is in a different spot. I am just assuming that I need to get a little bit of vacuum hose to plumb over to the new spot. Is that right?
Old Apr 20, 2011 | 06:05 PM
Pyros777's Avatar
Good catch! Yes I almost forgot about that. You do need to buy some hose to make it reach the new location. Can't think of anything else I missed.
Old Apr 21, 2011 | 12:37 AM
Yes there are, but there is little to no info out for them. nothing wrong with 80's
Old Apr 21, 2011 | 12:42 AM
carstedt's Avatar
subd to this for when my p&p head and tvs arrive!
Old Apr 21, 2011 | 01:57 AM
RooTBeeR's Avatar
yay! 1000's!!!
Old Apr 21, 2011 | 11:57 AM
Rodimus_Prime's Avatar
bottom two bolts are a real beeeeotch
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
