TVS needed for 400whp? Nope.... ;)
Old Nov 1, 2010 | 12:09 PM
Turbo Tim's Avatar
Well we decided to tweak my Redlines setup a bit, clean it up, put a good trans in it, etc. Ryan helped alot throughout the project. Just a reminder, my ZZP stroker 2.4L engine made 367whp last year on e85 fuel and ran a 12.2 @ 119mph. I had 1.2 second shift times though, my trans hated me, Ryan has pulled .15 shift times. So I decided to have a ZZP trans built with the 4.45 gear ratio, and we had the ZZP long tube header to test also.
So the current setup is pretty much the same as last year but with a ZZP 4.45 trans, ZZP longtube header, and since we can only get e75 currently we purchased some e98 fuel. We have also found some good info for e85 users, here in Michigan when it hits August e85 is then e80 and every 6 weeks from there it drops 5 more percent until January, then it starts to gain 5% every 6 weeks to get back to E85 (E85 is June/July only). But none of the pumps actually tell you what you are pumping in your tank.
Well Ryan helped me also clean it up under the hood a great deal, because it was mess from last year. Check out my new Heat exchanger!
Here is the dyno sheet:
Old Nov 1, 2010 | 12:12 PM
Dart_SI's Avatar
sooo, u pretty much have the fastest blown ecotec on here. nice!
Old Nov 1, 2010 | 12:13 PM
cmatthewb101's Avatar
Nice!
Cefaln452's Avatar
hm..
Old Nov 1, 2010 | 12:23 PM
Turbo Tim's Avatar
I have some stuff to fix though, I used a different trans case so it didnt have a speedo sensor in it, so I am going to tie the speedo wire into the rear wheel bearing. That will let me shift the car at about 9500rpm instead of 8192rpm. Because if your PCM doesnt see any MPH the rev limiter multiplier doesnt work.
Old Nov 1, 2010 | 12:25 PM
springerdesigner's Avatar
click
Old Nov 1, 2010 | 12:26 PM
ItalianJoe1's Avatar
You're spinning the 2.4L bottom to 9500?
Terminator2's Avatar
That SC is still moving air efficiently at 9500 RPMs?
Old Nov 1, 2010 | 12:29 PM
Staged07SS's Avatar
Administrator
Administrator
Tell me more about that heat exchanger
WSFrazier's Avatar
How does the ZZP 4.45 trans differ from Powell's 4.45? I noticed you said an different case.
Also, on the E85 subject.. Even though E85 drops to E70 in the winter, it is still very potent stuff and 99% of the people don't need to worry. Even on E70 I can run my same "track" timing map, upwards of 28-29.
PS: Would love to see what a TVS swap would give you.
Old Nov 1, 2010 | 12:32 PM
hawlyns711's Avatar
what size pulley is that on there?
nice numbers!
Old Nov 1, 2010 | 12:36 PM
InfraRedline's Avatar
This is impressive. Shows what a little more displacement and compression can really do
Old Nov 1, 2010 | 12:37 PM
ChevyRockstar's Avatar
Congrats ZZP
Old Nov 1, 2010 | 12:42 PM
Dart_SI's Avatar
you guys didnt put a k24 in there and just... disguise it to look like an lsj did you?
Old Nov 1, 2010 | 12:47 PM
ecotecturbo's Avatar
Very nice. I want to know more details.
Old Nov 1, 2010 | 12:52 PM
9500 redline i like that
goodjob on the #s sir
any videos?
Old Nov 1, 2010 | 12:56 PM
jonathan923's Avatar
holy..VERY NICE
Old Nov 1, 2010 | 01:11 PM
GoDFaTHeRSHaDy's Avatar
Very impressive
Old Nov 1, 2010 | 01:26 PM
hawlyns711's Avatar
dang I wish my saturn performed like this
WANT
Old Nov 1, 2010 | 01:30 PM
BYT*SS*TURBO's Avatar
Smashed that 300whp on stock blower theory lol! NICE
Old Nov 1, 2010 | 01:44 PM
rallycobalt06's Avatar
still would of been cheaper to do a turbo swap.
just giving you a hard time. congats
*ball tap*
that theory goes with bone stock LSJ, m62 & 93 octane pump gas.
everyone has known for months that a stock LSJ & m62 with E85 will get past that 300whp barrier with the proper tuning & fueling additions.
383_Stroker's Avatar
It's the TVS like paintjob on the M62 thats giving it all those extra horses...
NICE
Old Nov 1, 2010 | 02:28 PM
OriGinaL Condo's Avatar
awesome job guys
Old Nov 1, 2010 | 02:33 PM
JHans5774's Avatar
Thats some power right there lol
Bluelightning's Avatar
Got Bewst?
Sweet mother... TVS that thing!
