TVS Question...
Old Jul 11, 2009 | 12:55 AM
JAYNO20's Avatar
TVS Question...
Do you have to rebuild internals to get a TVS supercharger? What kind of gains do you get from getting one?
Old Jul 11, 2009 | 12:59 AM
HunterKiller89's Avatar
go find the TVS FAQ
Old Jul 11, 2009 | 01:00 AM
Admiral Jedi's Avatar
No. But you need to seriously upgrade your fuel system. You get moar powa! I guess the average is a total of 300 whp.
Old Jul 15, 2009 | 04:37 PM
JAYNO20's Avatar
from what i've read you really only need 60# injectors... what octane fuel should you run?
Old Jul 15, 2009 | 04:39 PM
GPZRider96's Avatar
premium. whatever the highest octane you can get is what you should run its a forced induction car
ls1fbody's Avatar
Haz l33t wheelz.
as high as possible. no lower than 91. Meth is a highly suggested mod for less that 93 octane.
Old Jul 15, 2009 | 04:42 PM
JAYNO20's Avatar
OK so with the TVS, its basically a bolt on and all that is really required is 60# injectors?
If that is the case then this is a mod that will be happening soon
Old Jul 15, 2009 | 04:45 PM
rocketrex's Avatar
I thought cooling mods are needed or is the meth all u actually need besides the tuning and bigger injectore
Old Jul 15, 2009 | 04:50 PM
Pyros777's Avatar
Definitely read the TVS FAQ. Theres a link to it in my sig.
Old Jul 15, 2009 | 04:52 PM
JAYNO20's Avatar
Yeah I read through that before... just trying to clear some things up.
Old Jul 15, 2009 | 04:58 PM
Pyros777's Avatar
Ok, cool. I frankly wouldn't recommend the bare minimum setup to anyone. Not enough cooling or air flow.
I think the bare minimum should include intake, exhaust, and at least a larger heat exchanger. That is of course in addition to the 60#'ers.
EGT and A/F sensors are a must in my book.
Old Jul 15, 2009 | 06:02 PM
Snakes709's Avatar
TVS = 60lb injectors, shorter belt or bigger tentioner, different boost gauge, h/e, meth, dual pass and a good tune
Old Jul 15, 2009 | 07:29 PM
WickedSS2005's Avatar
https://www.cobaltss.net/forums/show...ght=Harrop+FAQ
Can we get a damn sticky already!!! My FAQ would stop all these threads....
And no, now new boost gauge is needed because w/ proper exhaust you drop from 20 down to 17-18psi on the stock pulley. That's all you need to get started with the TVS. No one needs to be running a smaller than 80mm pulley until they have ran an 80mm pulley. Not everyone gets the concept of tuning the TVS
Old Jul 15, 2009 | 07:30 PM
Old Jul 15, 2009 | 08:58 PM
pmerritt's Avatar
one thing that confuses me is why is the cooling so important when everyone says that the TVS is more efficient and runs cooler at boost? I mean if your IAT's are actually cooler at boost i would say that more cooling is LESS mandatory. Don't get wrong, i still say it's a necessity but if it came down to exhaust or cooling i would say the exhaust is the more important of the two......is this incorrect?
Old Jul 15, 2009 | 09:00 PM
Snakes709's Avatar
i agree...i always thought the same thing.
Old Jul 15, 2009 | 09:21 PM
Deathscythe's Avatar
running it at lower boost levels really doesn't pose a threat at all as far as temps. But the power really isn't going to be there because of our lack of displacement. Problem is that power that you have everyday gets old after a little bit, and you want more.(moar)
Think of it this way. If the blower was designed to displace 1.0L of air like the m62, then it would be more efficient and run cooler. But the blower displaces 33% more air than the m62, so they aren't really on the same playing field. There is supposed to be an r900 model, that would be more comparable to the m62. There you would realize the gains and efficiency you're asking for in a stock-like sized blower.
More air being forced in from a larger blower is going to cause more heat. And the stock cooling system is barely enough to keep the stock temps under control.
Old Jul 15, 2009 | 10:01 PM
pmerritt's Avatar
i totally understand but if you've been following the tvs user comments they have reported that their temps are actually lower even with 20lbs of boost.
Old Jul 15, 2009 | 10:33 PM
Well, I would know that, especially since I am an owner of a tvs. One of those perks.
Old Jul 15, 2009 | 10:41 PM
G85 SS's Avatar
X2.
Temps climb fast with the TVS. People are getting their terms confused. It's more efficient but it is not cooler. My IAT2's usually sit ~15* above ambient. However my only cooling mods are OTT Heat Exchanger and distilled water/water wetter. With dual pass and meth which comes Saturday, they will drop a little more. However my IAT2's are usually below 150* even after 2-4th gear pulls.
Old Jul 15, 2009 | 10:45 PM
what is the max timing you are seeing?
Old Jul 15, 2009 | 10:47 PM
Old Jul 15, 2009 | 10:56 PM
G85 SS's Avatar
I'm holding 17* on a 11.6 AFR. Just keeping things 'safe' for the time being. I'm going to the track Friday and I am going to look for some race fuel to bump timing up. Also, meth goes in Saturday, so even if I don't find race fuel, I'll be bumping timing up with meth. I'm looking for the car to hold 22-24* of timing.
Old Jul 16, 2009 | 09:05 PM
must be nice. My car is running like half the timing it should be.
Turbo Johnny
Feb 21, 2019 09:41 AM
SmitBag
Sep 7, 2016 08:05 AM
Silverbullet333
Oct 4, 2015 02:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
RedLined
Sep 9, 2015 09:11 PM
