TVS Rotor Coating vs Methanol
Old Jun 24, 2009 | 12:17 AM
383_Stroker's Avatar
So, I know the methanol is eating the Teflon off my M62 rotors (one end is polished looking and the other still black, last time i looked..lol). This also makes the bores look really crappy in the SC (from running the trash around the bore).
Those of you running the TVS and methanol, how's the coating standing up? I'm gonna run it either way, it just hurts my feelings to do something destructive to a piece I just laid a big chunk of money down for.
Thanks!
Old Jun 24, 2009 | 12:19 AM
ajm5036's Avatar
Subscribed
I want to know as well, since I haven't hooked up my meth yet. Does anyone have real life facts about this?
Old Jun 24, 2009 | 12:20 AM
subd as well
Old Jun 24, 2009 | 12:24 AM
EXsoccer1921's Avatar
does the tvs even have a coating on the blades? i know some blowers don't even bother with it...
Old Jun 24, 2009 | 12:26 AM
Yeah.. they've got a black coating on them
ajm5036's Avatar
That is indeed what we are trying to figure out. What is it, and will it get worn away my methanol. Yes or no? Any vendors with some knowledge and not just vague speculations would definitely help!
EatonTVS07's Avatar
yea they do. Area47 has been running meth on his car ever since he had the TVS and he runs a pretty strong mix. his doesnt have any problems.
Old Jun 24, 2009 | 12:28 AM
ajm5036's Avatar
The question is not will there be problems it's will meth eat away the coating.
Maybe no problems now, but will it eventually?
Old Jun 24, 2009 | 12:32 AM
EatonTVS07's Avatar
thats what im saying. he doesnt seem to have any problems with the coating being eatin away. and hes had the TVS on for quite awhile
Old Jun 24, 2009 | 12:44 AM
ajm5036's Avatar
More opinions needed! Not that I don't trust you but.... well your being vague. Have you seen the inside of his TVS since he has been on meth?
Old Jun 24, 2009 | 12:53 AM
Darkmanx's Avatar
If meth isnt eating away at the m62 teflon rotors after people been spraying for years i doubt it will eat the tvs if it does you wont have the car long enough.
Old Jun 24, 2009 | 12:58 AM
burnrubr88's Avatar
Soo whats the huge problem if it does eat away some paint?...
Old Jun 24, 2009 | 02:09 AM
leviticus88's Avatar
He just said it IS eating away his coating on his m62...
I'd say it's really no that big of a deal but it's def not a the best thing ever.
Spray after the blower?
Old Jun 24, 2009 | 08:46 AM
It is eatting the coatting off of my m62.. :P
And even if it doesn't effect the efficiency of the blower very much to lose the coating. the particles are making thier way down to and clogging up the fins of the laminova cores, wouldn't you think?
Old Jun 24, 2009 | 09:30 AM
Zooomer's Avatar
Supporting Vendor
The older Eaton blowers used larger tolerances in the blowers with a teflon coating on the rotors. The M62 in the Cobalt does not have teflon on the rotors. It's more of a powder coat and doesn't flake off like the old blowers used to. It is considered abradable, meaning it's meant to 'wear in' As Eaton has tightened tolerances and used coatings the efficiency of the blowers has improved, especially at higher boost levels.
Methanol injected before the blower will speed the loss of coating but it is a small issue with the current generation of blowers. It will not clog the IC cores. It is still recommended to spray methanol after the blower using a blower spacer plate over the TB spacer plate.
http://www.zzperformance.com/cobalt_...=970&catid=143
-Zooomer, owner ZZPerformance.com; The forum's only Eaton Authorized Dealer/Rebuilder.
Old Jun 24, 2009 | 09:41 AM
Zoomer, You're alright.
Thanks!
Old Jun 24, 2009 | 10:38 AM
Darkmanx's Avatar
I didnt even know zzp had one of those damn........
Old Jun 24, 2009 | 11:07 AM
Josh@ottp's Avatar
Our info is pretty much the same, Just a few things to add. The older blowers 4th gen and down used an epoxy coating and to my knowledge there is no teflon in it. This coating was very resistant to fuels and is gray in color.
The 5th gen and tvs coating is an APC(abradable powder coating) that is graphite based, it is black in color and is not as resistant to fuels.
to finish this off, you should technically not run anything through the blower. It's designed to pump air and only air. Anything extra that you send through it(meth,water,n2o,gas, etc.) can and will void harrop's and eatons warranty.
Now I have and still will run meth,water,n2o,gas, etc. through the blowers as I have not had any problems doing so and neither have the masses.
Old Jun 24, 2009 | 11:09 AM
G85 SS's Avatar
No, you shouldn't. I believe the coating is just for noise reduction anyway. I could be wrong so don't quote me.
Old Jun 24, 2009 | 11:12 AM
id be interested in knowing more about the after blower spacer for meth as I havent seen one person run it.
Old Jun 24, 2009 | 11:13 AM
daythecountrydied21's Avatar
Does a s/c gasket need to be used with this?
Nice alternative to drilling into the IM to spray.
Old Jun 24, 2009 | 11:20 AM
Josh@ottp's Avatar
This is actually very easy to do when you are doing a dual pass install. all you need is the right drill and a 1/8 npt tap.
Old Jun 24, 2009 | 12:08 PM
Bika's Avatar
Fail Less.
If it is not recommended to spray before the rotors, why hasnt someone made a IM spacer with nozzle taps? Seems like someone should get in on this and make some $ while serving the needs of the communmity.
Old Jun 24, 2009 | 12:26 PM
G85 SS's Avatar
Demand would be my guess. I'm just tapping into the intake before the TB.
