Twincharge goes racing!
i knew when ZZP first released the kit it'd be ******* amazing, regardless of all the haters. i'm glad to hear you guys are backing your **** up finally.
if i could go back when i first started modding my car, this would of been the first thing i did. damn knows i could of afforded it then
good work. maybe in the future i'll be able to afford this beast of a ******* kit
The turbo is bigger, but it won't make more power than the 259 unless you are pushing 500+ whp.
The IC is a prototype race unit that we will have available. It is wider than our current IC and should offer a noticeable cooling advantage at power levels over 450whp.
No, we decided not to bring it because we were using the big slicks on Ryan's car. We have another set of rims on order so we can run both at the same time. We are going to want to line up a couple times when I put the 256 back on the LNF anyway.
I'm blown away that the motor held up to multiple track passes like that. I was sure that you were going to be making a thread about the blown motor not the great times. I'm impressed the setup is obviously capable and your the work is high quality.
I can never stop thinking about what would be possible with a similar setup w/ a proper intake manifold and turbo alone.
