Two Step Ignition?>
Old Oct 20, 2005 | 09:35 AM
Forced>Induction's Avatar
Two Step Ignition?>
Hey guys my name is Steve, I read the forums everyday trying to find new stuff for my SS/SC. Anyways, one of my friends has a MSD two step ignition. It allows him to step on the clutch and have a different rev limiter than when in gear, so he can get a better launch off the line... I was wondering if anyone new of a similiar setup i could possibly use on my Cobalt. Any help would be greatly appreciated. Thanks
Old Oct 20, 2005 | 09:41 AM
shcwv's Avatar
go to http://www.racelogic.co.uk/?show=Traction_Control my friend has this on his M3 maybe that is what you are talking about
Old Oct 20, 2005 | 09:42 AM
selfinfliction's Avatar
not that i'm aware of at the moment.
Old Oct 20, 2005 | 09:47 AM
Thanks alot for the input, I believe the one that my friend has is universal so i will keep you posted with what i find out...
Old Oct 20, 2005 | 10:00 AM
as funky as our cars are, does anyone know if the 2 stage dis systems will screw with the computer somehow? i know we got some strange stuff on the cobalts lol
Old Oct 20, 2005 | 10:04 AM
not really, what he's talking about is for launching cars at the strip. what it does is you can go WOT when the switch is flipped and it will only go to say 3000 rpm or whatever you set it for, then as soon as you get going you flip the switch and it goes to the normal redline. basically it just sets two redlines one for launching and the normal one
Old Oct 20, 2005 | 10:07 AM
Xenozx's Avatar
Well what if I didnt flip the switch? I gunned it off the line and IM guessing it would go to 3000 RPM's and just stay there, then shift and go to 3000 and stay there. That would be so strange....
Old Oct 20, 2005 | 10:15 AM
seen it happen before at the strip, it's easy to tell when it happens and is usually followed by the driver beating something inside the vehicle with his fists and throwing his helmet on the ground when he gets out
Old Oct 20, 2005 | 10:16 AM
no the way my friends works is off your clutch pedal... when the pedal is pressed there is a rev limiter set at like 3000 rpms then when its off and you mat the gas its normal redline
Old Oct 20, 2005 | 11:36 AM
yeah that's a switch... it's just wired up to the pedals and isn't stuck on your steering wheel or shifter knob..... same principal
Old Oct 20, 2005 | 01:55 PM
shcwv's Avatar
thats what the raclogic system does, its traction control, but you can get it with W.O.T. shifting and launch control. it works off the clutch for W.O.T. shift. when you push in the clutch, it drops the rev limiter so you dont have to let off the gas. and on the lauch control, you can set what you want the rev limiter to be. when you push the button, while the clutch is depressed, it wont let you rev above your preset limiter, then when you drop the clutch, it goes back to the factory rev limiter.
Old Oct 20, 2005 | 01:56 PM
shcwv's Avatar
oh yeah, its also universal to all cars that have abs and fuel injection.
Old Oct 20, 2005 | 01:58 PM
R33P3R007's Avatar
360 L337 User
so it will work on the SS SC? cause that would be neet to have
Old Oct 21, 2005 | 01:06 AM
shcwv's Avatar
yes it should work on your car, but it also cost like 1000. maybe we could get a group buy or something going for them and get a price break.
06MetallicBalt
Jul 20, 2025 08:47 PM
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
SSLOW06
Oct 1, 2015 07:21 PM
