Typical Stage 2 IAT2?
Old Nov 13, 2008 | 03:07 PM
FryLoch's Avatar
What are the typical IAT2s on Stage 2 or any for that matter.
I seem to be getting really high IAT2s really fast and will see as high as 180 after I've been driving hard... Need some help plz.
Gm is telling me the pump is ok but I disagree.
Old Nov 13, 2008 | 03:10 PM
ikeryder13's Avatar
i always run about 180-185 thats normal.. you need to worry at about 221 i believe is when the fans come on... someone correct me if i am wrong
what were they before the stage?
Last edited by ikeryder13; Nov 13, 2008 at 03:10 PM. Reason: Automerged Doublepost
Old Nov 13, 2008 | 03:12 PM
umrdyldo's Avatar
He said IAT2 not coolant temp.
180 is high you need cooling mods now. meth, extra heat exchanger, dual bypass, all of it.
Old Nov 13, 2008 | 03:13 PM
ikeryder13's Avatar
oh yeah huh lol... sorry bro...
Old Nov 13, 2008 | 03:16 PM
Hockeyman's Avatar
Alan, i just got my interceptor so i'll check mine out and we can compare. That sounds pretty hot, have you felt your pump to make sure it's working?
Old Nov 13, 2008 | 03:17 PM
PhantomSS's Avatar
i got as high as 180 before as well. Then i saw my reservoir for my IC was low. Check the other coolant neck behind the fans in front of the SC and see if there is coolant flowing/up to the neck. It should drop it to 160s under hard hard driving.
heat exchanger will drop it to 130-140 under hard driving.
Old Nov 13, 2008 | 03:28 PM
brandondrecksage's Avatar
your pump is out. it only cost $90 and is easy to install.
Old Nov 13, 2008 | 03:38 PM
FryLoch's Avatar
I topped off the tank, GM said the pump was working... Where exactly is the pump and when it's going out does it start to flow less and less or just stop?
Old Nov 13, 2008 | 03:47 PM
PhantomSS's Avatar
it stops....
dont just top it off... bleed it off.
start the engine, fill......shut off....wait for bubbles to come up
repeat
Bika's Avatar
Fail Less.
1. Open the resivior cap
2. Turn the pump on by either starting the car or jumping the terminals on the relay.
3. Insert a screwdriver or dow rod of some sort until it touches the bottom of the resivoir.
If the pump is running you will feel the rod be sucked to the right from the fluid flow.
The pump is located on the bottom front of the engine. Its a small electric pump with a plastic housing and 2, 1/2" coolant hoses coming off it and a small wiring harness. very easy to replace. you will get coolant everywhere, but its easy.
Old Nov 13, 2008 | 03:48 PM
Sizzle06's Avatar
I see 135 to 145 with a 2.8 and H/E.I am going to put the stage 2 pulley nate made for me and see if it drops the temps down.
Old Nov 13, 2008 | 03:49 PM
PhantomSS's Avatar
im not worried too much about 135.... even with methanol + H/E it tops out at 135 end of 3rd and hits 145 at idle under hard driving.
I looked at my s2 logs with just H/E and it was the same.
Old Nov 13, 2008 | 03:52 PM
ViSiONZ's Avatar
Mine is around 135 also.
Old Nov 13, 2008 | 03:54 PM
1BADSS/SC's Avatar
u can always use the AC trick
Old Nov 13, 2008 | 04:36 PM
Bika's Avatar
Fail Less.
135 is normal for stage 2 with no other mods. i see between 135-145 after a w0t pull and i have a 2.8 and H/E.
Old Nov 13, 2008 | 04:56 PM
PhantomSS's Avatar
and it doesnt go less than 135 with methanol either....
however it does get rid of heatsoak rather quickly.
Old Nov 13, 2008 | 05:08 PM
FryLoch's Avatar
Yea, it has to be dead. I'm getting 176 top of third in hard accel. Granted I don't have a H/E but that's ridiculous...
Old Nov 13, 2008 | 05:10 PM
1BADSS/SC's Avatar
u could drop the heaton and get a more efficient SC
Old Nov 13, 2008 | 05:12 PM
invisible's Avatar
Your pump is out. My IAT2's peak at about 130 and I have a 2.8.
Old Nov 13, 2008 | 05:15 PM
PhantomSS's Avatar
tap it with a hammer a few times to see if it loosens the plastic shavings. Otherwise its cheap to replace.
Old Nov 13, 2008 | 05:40 PM
FryLoch's Avatar
Tried the hammer and AC trick. Neither worked.
I revved the car once very quickly to 3k rpm and it jumped to 131 IAT2...
I'm going to talk to the dealer again tomorrow because this should be covered under the warranty!
Old Nov 13, 2008 | 05:43 PM
fzn14's Avatar
https://www.cobaltss.net/forums/show...134882&page=10 here is an example with i IAT2's, granted there was a boost issue at the time but thats a 2.8 pulley with stock H/E
Old Nov 13, 2008 | 05:46 PM
FryLoch's Avatar
Yea, I was feeling the pump while the car was running and I couldn't feel any vibrations coming from it...
Old Nov 13, 2008 | 05:53 PM
fzn14's Avatar
Are you losing any boost? Cause i know for sure my pump is running and it ran 15-16 pounds for like 2 weeks and then would hit 15-16 and bleed off to twelve as you can see there, so all i did was bypass the bypass valve and BAM at 16-17 pounds but the MPG wont get any higher then 26.5 and the car is no running issues....So any conclusion lol?
Old Nov 13, 2008 | 06:07 PM
FryLoch's Avatar
No, not losing any boost it's just really freaking HOT! I'm running the GM Stage 3 pulley and it consistently hits 16.4 PSI. Well that's in top gear, I haven't payed attention in lower gears. So I may be losing boost.
I called up the service rep and told him that I was sure the pump was out after checking it. I have an appointment tuesday morning and i'm hoping they just replace and not jerk me around...
