Ultimate Cooling: Question
Old Nov 9, 2007 | 09:09 PM
IR0NS1N's Avatar
Ok Is it possible to do a Meth/Water injection, New heat exchanger, and a Dual pass? With dual pass is there anyone that does the whole Option B that you can purchase? Does the resevor for the Meth/water - Option B both need the same bolts to mount? ( I assume they use the two that stick up near the passanger strut where the 2.2 air box is?)
Im starting to get very serious into cooling. any help would be great!
Old Nov 9, 2007 | 11:23 PM
cobaltBlackss's Avatar
It is possible to do all three. That is my set up. Option B is very difficult. I gave up trying to find out how to route the hose so it would not drop too low.
Old Nov 10, 2007 | 11:07 PM
JapEatr's Avatar
South Central *********
can u elaborate on what u mean the hose not dropping too low, i have this mod and thought the routing was all that mattered
Old Nov 11, 2007 | 01:25 AM
IR0NS1N's Avatar
yea can you explain what you mean?
Old Nov 11, 2007 | 04:56 AM
ItalianJoe1's Avatar
If your hose doesn't stay below the level of the resivior, you get air in the system. I don't think you can get to low, but if you are trapping air bubbles you will lose coolant flow. You want all hoses going uphill to the resivior, which must be the high point in the system. At least I think thats what he's talking about here.
Old Nov 11, 2007 | 01:26 PM
^^^thats what I meant. I couldn't find a way, with the amount of hose I had, to make it work.
How did you route yours?
Last edited by cobaltBlackss; Nov 11, 2007 at 01:26 PM. Reason: Automerged Doublepost
Old Nov 11, 2007 | 01:28 PM
Coblt ss super's Avatar
Option B can be purchased at CrateengineDepot for like 100 bucks, second reserve tank and all, and the line from the second bottle to the lines has to be higher than the connection at the T to the line coming out of the dual pass plate?
Old Nov 11, 2007 | 02:47 PM
IR0NS1N's Avatar
You got a link to the option b? I cant find it
Old Nov 11, 2007 | 02:49 PM
http://www.crateenginedepot.com/stor...P1838C221.aspx
Old Nov 11, 2007 | 02:58 PM
IR0NS1N's Avatar
Awesome thanks!
Old Nov 11, 2007 | 03:05 PM
anytime
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
