under drive pulley information
Old Jun 23, 2009 | 03:56 PM
brickerenator's Avatar
677 dollars! good god!
but i needs one for my daily driver xfe!
Old Jun 23, 2009 | 03:58 PM
Johnboy12358's Avatar
Originally Posted by Rodimus_Prime
ive never saw a single bottom end failure in any ecotec engine as a result of a lightened crank pulley and thats since 2002
but didnt he also have one of the first gen ones that became on here known to leaking the crank seal?
im with rodiums on this one i havnt seen one as a direct result of a pulley on here.
Correct me if I'm wrong, but i thought our cranks were internally balanced and the crank pulley was just that, a pulley and not a harmonic balancer as well.
Considering the small amount of power that the part gives you, I would *personally* rather not take the chance.
Old Jun 23, 2009 | 04:23 PM
So wouldnt a smaller supercharger pulley be just as "damaging"? its all on the same belt resulting in the same thing in the end isnt it? its not weight saving but its spinning everything faster....
Old Jun 23, 2009 | 04:50 PM
jschru's Avatar
this article is talking mainly about the effects of removing your harmonic damper which has nothing to do with our cars. a pulley is a pulley. a harmonic damper is something completly different.
"The popular method for making power pulleys on E36 engines is by removing the harmonic damper and replacing it with a lightweight alloy assembly. This is a very dangerous product because this damper is essential to the longevity of an engine. The substitution of this part often results in severe engine damage."
since the harmonic damper on an ecotec is not directly related to our crank pulleys i don't see how this article can apply to our cars in any way unless someone is deciding to remove their harmonic damper
Old Jun 23, 2009 | 04:52 PM
From what I understand, no, changing other pulleys doesnt affect the crank in the same way, because you are not lightening the rotating mass of the crankshaft itself, just the load placed on it.
Are you saying that this applies to the balance shafts in the engine, as instead of the crank pulley?
Last edited by Johnboy12358; Jun 23, 2009 at 04:52 PM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 04:57 PM
Area47's Avatar
Rent me! per hour
ya know what? you want to take the free advice and nit pick it? fine.
apparently some fo you did NOT read the entire article anyways. so i really do not expect you to grasp and form of this concept anyways.
Old Jun 23, 2009 | 05:09 PM
jschru's Avatar
i'm just saying this doesn't apply to our cars. and i did read the whole article. i think the problem is that you don't understand the article.
sorry
Old Jun 23, 2009 | 05:13 PM
burntorange's Avatar
lol ^
Old Jun 23, 2009 | 05:15 PM
Area47's Avatar
Rent me! per hour
actually it does apply to the ecotec series.
just like the nissan owners with the vq series think they can run a lightened crank pulley and think it will be ok.
what happened? it starts to leak oil. then makes noise. then the crank dies.
there is a reason why the grand am cars, and the uber lee7 time attack car runs a stock flywheel and a stock crank pulley.
Old Jun 23, 2009 | 05:19 PM
/me raises hand
I took it, and will gladly accept any more you are willing to throw out. I'm not afraid to admit that I dont know as much as some other people and I am willing to learn
and damn dude you have some of the weirdest sayings in your sigs sometimes....
sorry
seriously?
Last edited by Johnboy12358; Jun 23, 2009 at 05:19 PM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 05:25 PM
  #36
rico's Avatar
thanks for the info
Old Jun 23, 2009 | 05:40 PM
  #37
the mrz pulleys fixed this problem that the jbp pulleys were doing with the leaking oil
Old Jun 23, 2009 | 05:52 PM
  #38
Area47's Avatar
Rent me! per hour
stock flywheels are the weight they are
stock crank pulley's are the weight they are
same thing with the crank trigger.
Old Jun 23, 2009 | 05:57 PM
  #39
what part do balance shafts play in the internals of the motor?
we can get neutral balance shafts
also as said above gm offers a lightweight crank pulley as well.
im not arguing you nor the article im just trying to better understand it for myself
Last edited by 07MetallicSC; Jun 23, 2009 at 05:57 PM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 06:07 PM
  #40
Area47's Avatar
Rent me! per hour
the shafts cancel out vibrations caused by the typical nature of a 4 cylinder itself.
Old Jun 23, 2009 | 06:13 PM
  #41
1badBlueberrySC's Avatar
And he interrupted me while watching "OWW MY *****!" and that is NOT COOL!
Old Jun 23, 2009 | 06:25 PM
  #42
i see ati makes a damper for the 2.2 do they for the 2.0 as well?
i see that gm also sells a lighter weight crank pulley as well, whats the deal with that?
Last edited by 07MetallicSC; Jun 23, 2009 at 06:25 PM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 06:35 PM
  #43
jschru's Avatar
if the ecotec harmonic damper is sperate from the pulley ( which is what people are saying) you will be fine. if this really is the case the crank has been balanced without the pulley and therefore adding a lighter pulley WILL NOT cause failure.
in my opinion a lighter crank pulley is not worth the money for the amount of power it gives you
Old Jun 23, 2009 | 07:00 PM
  #44
domin8_gt's Avatar
You are mistaken. Here's the exact rule for that.
7-8.2 The following components may be tooled enough for balancing only - pistons, rods,
crankshaft, harmonic balancer, flywheel and clutch.
And pay careful attention to this rule:
7-8.4 The crankshaft and harmonic balancer may weigh no less than the OEM specification.
Both rules tell you that you can alter the pulley, heck, even use aftermarket, but it must weigh no less than the OEM pulley.
Source: http://media.grand-am.com/assets/KONIRules.pdf
Area, I have nothing but mad respect for you. You are very knowledgeable, and I pay careful attention to what you have to say. I even read articles you post in their entirety. I don't think you need to get upset becasue a few people don't agree with you. After all, many more are paying attention. I'm a noob when it comes to this ****. Since I've already fucked up and installed the Spec lightweight flywheel, figure I might as well go with the MRZ pulley, but what about the balance shaft people are talking about? BTW, my car will be promoted to "toy" soon. I'm looking at getting an Avalanche as a DD (and so that I can tow my toy when it breaks).
Old Jun 23, 2009 | 07:26 PM
  #45
Area47's Avatar
Rent me! per hour
the stock ecotec crank pulley is in fact a damper.
gmr removed the exedy hyper single, and twin disc clutches from the test cars due to harmonic issues above 7k rpms. these issues resulted in lower end failures. testing was also conducted on lighter crank pulleys and such and resulted in the same failures. the time attack car, and a few others that followed the same shoes so to speak met this fate.
the only issue with the neutral balance shafts is sustained rpms north of 7500 rpms. the shafts spin at twice the crank speed to counteract the vibrations common with 4 cylinders. when rpms are sustained above 7500, you run the likely risk of snapping the shaft, or just destroying the block itself upon the shafts oscar winning performance exiting stage left.
Old Jun 23, 2009 | 07:32 PM
  #46
so basically under 7k which is what majority of us redline at youll be fine? the failure is mainly above 7k?
Old Jun 23, 2009 | 07:36 PM
  #47
Area47's Avatar
Rent me! per hour
they met the destructive fate faster due to higher revolutions.
Old Jun 23, 2009 | 08:25 PM
  #48
damien's Avatar
Can't believe half these people didn't know the pulley is the balancer.
Old Jun 23, 2009 | 09:04 PM
  #49
Area47's Avatar
Rent me! per hour
amazing how that works isn't it
Old Jun 23, 2009 | 10:07 PM
  #50
paul1588's Avatar
area, im running a hyper single so is my crank all off balanced now
