Updates on ZZP Turbo Powered LSJ
Old Aug 11, 2010 | 04:32 PM
  #76
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by selfinfliction
why swap the blocks instead of sleeving?
because the LNF is a gen2 ecotec block. the sleeves are good to 700hp
Old Aug 11, 2010 | 04:34 PM
  #77
rico's Avatar
he on stock sleeves on block at 600 hp. so that saves money from sleeving a lsj block of what i seen lol
there u go
Old Aug 11, 2010 | 04:50 PM
  #78
Matt M's Avatar
Originally Posted by INFE
I don't think it's a 4 speed but I think they start in 2nd At the track
Definitely not starting in 2nd. Even with the 4.45 final drive and stock height tires, Ryan is shifting 2-3 at 90 mph. That would be a pretty tall gear to start in.
Old Aug 11, 2010 | 04:59 PM
  #79
INFE's Avatar
Interesting you guys must 1-2 shift that car like there is flashing light in your rear view! Lol
Old Aug 11, 2010 | 06:22 PM
  #80
selfinfliction's Avatar
ah ok...
for a cheap substitution couldn't people just buy the lnf sleeves and put them in an lsj or are there block differences as well? just asking out of curiosity cause i've already got dartons
Old Aug 11, 2010 | 07:21 PM
  #81
Matt M's Avatar
ah ok...
The gen 2 blocks are reinforced in problem areas and lightened in others with a little more cooling passage capacity.
Old Aug 11, 2010 | 07:36 PM
  #82
ok thanks for the info..
question on your kit for the lsj... it says it removes the stock cooler for the lsj, but an fmic is $1000 extra. is the basic setup assuming that the customers will do their own fmic?
Old Aug 11, 2010 | 09:59 PM
  #83
Matt M's Avatar
The site isn't really set up right. I'm not sure if we will offer a kit without IC. I'd rather only offer complete kits. Any time we offer a kit with less parts included, tech support requirements quickly increase.
Old Aug 11, 2010 | 10:10 PM
  #84
Snakes709's Avatar
you know what i would love to see, just thought of this since i just finished watching TV, i wanna see ZZP on Pinks All Out...lol. You only see muscle cars, i would love to see a cobalt come out and kick everyones ass..lol
Old Aug 11, 2010 | 10:12 PM
  #85
InfraRedline's Avatar
I think they are actually gonna be on it at the end of the month
Old Aug 11, 2010 | 10:13 PM
  #86
Stiner's Avatar
thought the exact same thing today when I saw this thread
Old Aug 11, 2010 | 10:23 PM
  #87
terry11's Avatar
So get a used gen2 block and bolt an lsj head on it... Could it really be that simple?
Old Aug 11, 2010 | 10:32 PM
  #88
ebristol's Avatar
You still need to worry about the rotating assembly. I am not sure how much those DI pistons would like none DI injectors.
And the LE5 comes with 6 bolt crank while the LSJ has an 8 bolt. So you would have fun matching a flywheel to a clutch to bolt up the trans.
Old Aug 11, 2010 | 10:42 PM
  #89
Matt M's Avatar
Ryan will have a reasonable chance of being in the class that they choose. My Cobalt won't be able to run without a cage, so I'm going to be running my Grand Prix, which will be too fast for the field.
Old Aug 11, 2010 | 10:43 PM
  #90
cli3e0339384398jk's Avatar
Nice results
Old Aug 11, 2010 | 10:56 PM
  #91
BLAZIN07SS's Avatar
I'm too JDM for you
you can put LSJ pistons in it
Old Aug 11, 2010 | 11:54 PM
  #92
Ryan@zzp's Avatar
i used a set of prototype piston for the LSJ (which we should have done now or instock very soon) a set forged rods, oem headgasket, ARP head studs, LSJ cyl. head, some ZZP seasoning,bolt it all together on one engine stand equals sweet. Its really that simple.
Old Aug 12, 2010 | 12:05 AM
  #93
Brags's Avatar
Isn't 07+ L61 genII also?
Old Aug 12, 2010 | 12:09 AM
  #94
Ryan@zzp's Avatar
Not sure.
Old Aug 12, 2010 | 12:20 AM
  #95
ralliartist's Avatar
Ryan,
Just curious why you guys didn't try to get more out of the twincharged setup. You were still on the stock head and stock cams, but with this new setup, it's all built.
Old Aug 12, 2010 | 03:28 AM
  #96
Brags's Avatar
just found info on ecotecforum, Significant improvements for 07 L61 and LE5 include gen II block
Old Aug 12, 2010 | 06:02 AM
  #97
terry11's Avatar
Awesome! So in your opinion what should I do. Right now I'm about to go twincharge but I'm not sure. Can it be done without having a lot of issues for a weekend driver? I'm not looking for a ten second car, but this lag is killing me...
Old Aug 12, 2010 | 08:11 AM
  #98
rico's Avatar
because tranny from a lsj bolts right on to a lnf block right? with no problem like the guy above stated about 6 and 8 crank bolts?
Old Aug 12, 2010 | 08:13 AM
  #99
BLAZIN07SS's Avatar
I'm too JDM for you
le5 is 6 bolt. lnf is 8 bolt. if you have a lnf block everything will bolt up right together. stop overthinking it!!!!
Old Aug 12, 2010 | 08:26 AM
  #100
Ryan@zzp's Avatar
You can def. go twincharge without a lot of issues and keep it completely driveable. What size turbo do you have. If you have the porper setup lag shouldn't be that bad. With a porperly sized turbo, you can have an 11sec car with hardly any lag. Matt's LNF is a perfect example.
Word!
