upgrade intercooler pump, i have pics
Old Nov 19, 2008 | 11:11 PM
Sharkey's Avatar
upgrade intercooler pump, NOW INSTALLED pics page 2
now installed, pics in post 32
a little backround here, like many people i have experianced an intercoolerp pump failure. the gm dealer wants $425 (thats with my 20% off through my shop), and ford wanted $300 for the stock bosche pump. i was looking into getting one off e-bay, but even by the time i got it it would have cost me more than a pump thats going to fail again in a year and a half should.
after some searching here is what i came up with
its a meziere wp136s, designed for air/water intercoolers and remote cooling systems. it flows 20gpm, draws only 5 amps (stock draws 4 amps). meziere is known for their reliability, this pump is designed for over 3000 hours of constant use and has a 2 year unlimited mile warrenty. its also fully rebuildable with parts avalible. the only downside to this pump is that it must be mounted vertically with the motor on the top, this is to reduce the chance of a motor failure should the pump seal leak.
with the low amperage of this pump, i should be able to wire it to the factory intercooler pump wiring without adding another relay. as a precausion i will add a fuse at the pump just for redundantcy (a fuse comes in the wiring harness with the pump). i will need to make a bracket up and re-do some of the plumbing.
as for the benifits of going this route, for me not having to put a new pump in every year and a half is the biggest one. im not sure if i will see any improvment in cooling. the manufacturor of the laminova recomends for our short cores to have minimum 10gpm of coolant flow for one core, more if you run cores in series. the stock pump falls very short at 6-7gpm. for a dual pass setup the coolant flow rate will be right on for whats recomended. i think it would further improve a single pass manifold. as for testing it vs stock, i dont really have a lot of time. i have a dual pass end plate and surge tank waiting to go on the car, i will likley do it all in one shot so my results could be a little scewed, i may need some input from others to help come up with the right conclusion from this experiment. keep in mind im not doing this just for cooling, its more for the fact that i need a replacment.
Old Nov 20, 2008 | 12:40 AM
cahtr6's Avatar
Thanks for the info two more questions where? and how much?
Old Nov 20, 2008 | 12:49 AM
Sharkey's Avatar
summitracing.com, $189 for the pump and the 2 fittings were $16 each. the fittings are special, they arent pipe thread they are -12 ORB (o-ring boss). basicly they are an AN thread without the 37* flare on the end and they use an o-ring to seal them.
Old Nov 20, 2008 | 12:54 AM
cahtr6's Avatar
Thats easy enough looks like a good upgrade I am planning to do my dual pass and H/E over the holidays thought this would be a good time for this as well.
Old Nov 20, 2008 | 09:40 AM
mperez's Avatar
Looks Great Keep Us Posted
Old Nov 20, 2008 | 09:42 AM
csementuh's Avatar
Click...
Old Nov 20, 2008 | 10:01 AM
ecotecon18s's Avatar
theres a website you can get the stock pump for like 95. its a ford performance company. I bought one for my last cobalt when the pump went out. I think its lightningperformance.com or something. The Cobra Mustang and Lightning use the same pump. It's a complete plug and play, the connector and all. But your find looks pretty promising too...I wanna know more when you find it out....
Old Nov 20, 2008 | 10:30 AM
freakta's Avatar
nice find
Old Nov 20, 2008 | 10:39 AM
stonny9's Avatar
05 here with 42,000 miles and still on the stock working pump. Are u more prone to failure when adding a dual-pass, opt b, and/or extra h/e? I would think so as u are adding more fluid causing the pump to work harder.
Think of it this way is it easier to blow through a 3" straw or a 8" straw.
Create a how to when u are done.
Old Nov 20, 2008 | 10:47 AM
lsjwannabe's Avatar
I thought about running a pump like this, please post any iat info.
Old Nov 20, 2008 | 07:06 PM
Sharkey's Avatar
it will likley be a couple weeks before i get it on. as i said, im doing my dual pass at the same time so results may be a bit scewed, but ill post up when its on.
yea i know there are sites that have the stock style pump for $95, however convert to canadian and add shipping, taxes and the ups/fedex surprize butseks fee and it idnt cost effective to buy a pump thats going to fail within a couple years.
i should also mention that this pump is a common replacment on the cobra/lightning.
Old Nov 20, 2008 | 07:09 PM
chris88z24's Avatar
Please post your IAT2's (if possible) after this swap. Thanks
*click
Old Nov 20, 2008 | 07:16 PM
WickedSS2005's Avatar
Hmm, I've thought about this, but my pump is working. For right now, I'm not fixing what isn't broke
Old Nov 20, 2008 | 07:20 PM
RedEcotecSS's Avatar
before and after IAT2's would be great..
Old Nov 20, 2008 | 08:01 PM
Johnboy12358's Avatar
I smell a how to....
Old Nov 20, 2008 | 08:04 PM
pimpnwink's Avatar
you best get some detailed info or the cooling gods on this forum will slay you.
Old Nov 20, 2008 | 09:38 PM
Sharkey's Avatar
trust me, ill be taking pics and will do some good testing. like i said, i need some time and thats something i dont have right now
Old Dec 1, 2008 | 12:00 AM
ColeJJones's Avatar
Bannned
anyone know the fitting part number on summit?
anyone know the inside diameter of the coolant hose?
anyone?
Old Dec 1, 2008 | 12:21 AM
HunterKiller89's Avatar
ID of coolant hose is 3/4". idk the fitting part #, but the ID diameter should narrow it down
Old Dec 1, 2008 | 12:31 AM
ColeJJones's Avatar
Bannned
perfect. thanks.
http://www.meziere.com/ps-892-860-wp136s.aspx
the fittings
https://www.meziere.com/ps-833-801-wp12034b.aspx
Old Dec 1, 2008 | 03:29 AM
tdipowered's Avatar
ok so how do you check the temp for the aftercooler? iat2s or what not? yea im a noob
Old Dec 13, 2008 | 07:40 PM
Any new info on this...??
Old Dec 13, 2008 | 08:31 PM
Sharkey's Avatar
not yet unfortunetly. the only bit closer i am is i have the peice of aluminum to build the bracket for the pump. ive just had less than no time to even think, and with christmas a couple week away, ill have even less time. i have a few days off at christmas, i hope to have some time then to do it.
Old Dec 13, 2008 | 08:50 PM
rockSTAR_SS's Avatar
Excellent find! Subscribed!
My pump is dead, and I have all the time in the world to install it. If I had the money for it I'd do it.
Old Dec 14, 2008 | 03:04 PM
Ok...i just re-read the OP...i thought you could mount it sideways like the stock pump. well....maybe fabbin up a bracket wont be that bad...it should all pay off in the end.
