UPS Finally got here with..
Old Jan 20, 2011 | 04:42 PM
Killa702's Avatar
My ZZP Stage 3
E85 canned tune, 2.7 pulley, plugs, 80lb injectors
S3 Heat Exchanger
Old Jan 20, 2011 | 04:43 PM
CobaltVenomSS's Avatar
might wanna get a dual pass with that 2.7
Old Jan 20, 2011 | 04:47 PM
Killa702's Avatar
i dont think i need it
Old Jan 20, 2011 | 04:49 PM
revolution607@yahoo.'s Avatar
why is that?
jonathan923's Avatar
the more cooling mods u have the better and safer man. unless ur doin a meth kit as well or corn...
Old Jan 20, 2011 | 04:51 PM
i might go 2.7 when i put my meth on here soon
Old Jan 20, 2011 | 04:53 PM
coopercharge's Avatar
the e85 will cool cylinderhead temps but your iat2's with a 2.7 will be a high I would strongly recommend a dual pass.
Killa702's Avatar
yea, the caption in the pic with the ecu sais (E85 can tune) with 80lb injectors.
im gonna run the can tune for about a week then go get a dyno tune
Pyros777's Avatar
Yeah someone here locally made 297whp on a 2.7, FMHE, and E-85. The dyno might have been happy, but as long as youre running meth or E-85 the cooling requirments are significantly less.
BUT, if youre on regular 93, I'd recommend it.. it won't make things cooler, but it will help recovery time after a pull.
sounds good man! what injectors will u be running? and who tunes u btw..
Old Jan 20, 2011 | 04:55 PM
60 lb injectors... a local guy down the street tunes me lol
Old Jan 20, 2011 | 04:57 PM
Killa702's Avatar
yea as soon as i install it im gonna get some E85 put it in the car and start her up
If i need dual pass i'll get it i guess, its not that much
Old Jan 20, 2011 | 05:09 PM
SuckMyBalts's Avatar
I am really really curious to see how this canned tune performs. I have a feeling the fuel trims are going to be off....A LOT. Really wish you had an interceptor to check on things.
Old Jan 20, 2011 | 05:16 PM
SuperchargedSS's Avatar
Wow, I feel like I went through a time machine..
insylem's Avatar
Somebody is going to have alot of FUN!
Congrats dude!
There's plenty of info here, if the search worked.
Old Jan 20, 2011 | 05:56 PM
Killa702's Avatar
Is there a how to on how to install the s3?
Ive seen the how to about the ottp h/e with the bumper still on.
And is the bumper a pain to take off? or easy?
Old Jan 20, 2011 | 05:57 PM
its alot easier with it off
Old Jan 20, 2011 | 06:03 PM
Bluelightning's Avatar
Got Bewst?
Just jack the car way up in the front, remove the grille and install it. No need to take off the bumper.
Killa702's Avatar
I was readong on some other threads that you can install the h/e with the bumper on, just use blocks of wood or jack stand to hold it up, is this right?
Old Jan 20, 2011 | 06:08 PM
Got Bewst?
Yup. I jacked the car up, used a jack to raise the heat exchanger, looked back to make sure it's straight, marked my holes and drilled
Old Jan 20, 2011 | 06:09 PM
yes it is possible to install the h/e without removing the bumper.
Old Jan 20, 2011 | 06:20 PM
Killa702's Avatar
Do i just add straight Dex cool till its filled up after installing?
Old Jan 20, 2011 | 07:42 PM
Killa702's Avatar
anyone
Old Jan 20, 2011 | 07:49 PM
05Slowline's Avatar
50/50 not straight..
