using meth
Old Feb 11, 2009 | 06:44 PM
ssyellowss's Avatar
using meth
to those guys using meth, are you running it everyday, meaning you dont have tunes you switch out for track day?
Old Feb 11, 2009 | 06:46 PM
1badBlueberrySC's Avatar
I run it all day everyday... or anytime I am over 4psi
Old Feb 11, 2009 | 06:47 PM
ssyellowss's Avatar
oh yeah thats another question i had lol. what pressure are you activating it? how hard is it to tune for?
tdipowered's Avatar
lol i cant wait!!!
Old Feb 11, 2009 | 06:48 PM
ssyellowss's Avatar
Originally Posted by tdipowered
lol i cant wait!!!
for?
Old Feb 11, 2009 | 06:49 PM
is it hard to tune for.... well it's not easy!
Old Feb 11, 2009 | 06:51 PM
ssyellowss's Avatar
lol. a knowledgeable tuner shouldnt have too much of a problem?
Old Feb 11, 2009 | 06:52 PM
well mr. wizard why ask if it's easy!
Old Feb 11, 2009 | 06:58 PM
Hockeyman's Avatar
every day, but only when i get on it.
Old Feb 11, 2009 | 07:30 PM
tdipowered's Avatar
i cant wait to get meth
Old Feb 11, 2009 | 07:40 PM
RedEcotecSS's Avatar
same here
Old Feb 11, 2009 | 07:43 PM
freakta's Avatar
i have it set for rpm and throttle position. i dont think i have it set for boost.
anyways its great just make sure your tuner knows how to use it
Old Feb 11, 2009 | 07:53 PM
tdipowered's Avatar
really how? ^
Old Feb 11, 2009 | 07:55 PM
ssyellowss's Avatar
i thought it was boost activated????
Old Feb 11, 2009 | 08:00 PM
tdipowered's Avatar
yea thats what i was thinking
Old Feb 11, 2009 | 08:05 PM
freakta's Avatar
the kit i got had a controller on it.
at 3k rpms as long as im more than 1/2 throttle it starts to pump 50% power then at 4k rpms its at 100% pump power
Old Feb 12, 2009 | 01:24 AM
tdipowered's Avatar
yea thats the progressive the base kit comes on all at once at a set psi
Old Feb 12, 2009 | 01:43 AM
Yes that is the difference between progressive and boost activated.
Boost activated setups are more simplistic, less to go wrong with!
Old Feb 12, 2009 | 02:05 AM
Sharkey's Avatar
there is also progressive boost activated, like the devils own controller. it comes on 15% at the low set level and ramps up to 100% for whatever you set it. its kind of pointless for a supercharged motor though because your supposed to have it set for max flow at 3/4 boost, but with our cars the boost goes up to around 3/4 of max boost just by stepping on the throttle, and it ramps up a couple more psi till you hit redline.
i run an on/off boost switch set at around 8psi running a 2gph nozzle with 20% meth on a stage 2 tune with a 2.9" pulley. no issues, doesnt run stupidly rich, basicly just running it for cooling and the little bit of meth stops the pcm from pulling 2-3* timing that it pulls with the meth off.
Old Feb 12, 2009 | 02:14 AM
cobaltss86's Avatar
drugs are never the answer
Old Feb 12, 2009 | 07:31 AM
freakta's Avatar
meth isnt a drug hahaha its a lifestyle chioce
Old Feb 12, 2009 | 07:55 AM
roadrage06's Avatar
Here's a question I've always had and still bugs me.
You have to tune for it. So what happens when/if you run out? Does it pump air in or is there and auto-off? How does this effect performance?
Just thinking cuz I know there are times where you just don't get around to buying more of something.
Old Feb 12, 2009 | 09:10 AM
383_Stroker's Avatar
If you tune for it, and run out.. You have the chance of massive heat.. and massive knock.. which, as you know, is very hard on motors..
Old Feb 12, 2009 | 09:23 AM
Mattman6's Avatar
yea if your tuned for it, you would make time to fill it up. Or your motor may blow.
Old Feb 12, 2009 | 09:30 AM
roadrage06's Avatar
^^thought as much...lol. Thanks for the info.
