Using Oil
Using Oil
So today i go to do an oil change on my car nothing fancy just the regular. After I pulled out the plug let it drain for about ten minutes then put the plug back in I realize there isn't as much oil in my pan as there should be, So i pour the oil out of the pan into a gallon container and it fills it up about three fourths of the way.
So my question is wtf? is my car using three quarts of oil every 3000 miles? Has anyone else had this problem?
anyone? post even if it doesn't happen to you i just want to know if i'm an oddball on this one, and anyone else have alot of black smoke when u first start it up? sorry if its been mentioned but i did search.
Sounds like a trip to the dealer is in the very near future for you. You should not be burning 3 quarts of oil every 3k.
And you shouldn't have black smoke on startup.
Make sure you check it after anyone besides you changes it & then you will know whats up !!!!!
I hope it's just a miss que from filling as 3 QTs would mean bad rings or intake or something internal is not right.
If you suspect the problem may be related to recent mods, unmod the mod and see if the problem goes away. If the vehicle is still under warranty, take it to the dealer. Unmod the mod if taking it to the dealer because they may blame the mod.
If this is the first oil change or if the oil was recently changed, the person filling the engine may have assumed that four quarts was enough because it is a four cylinder. In the case of the super charged engine, this would not be true as the SC 2.0L holds 6qts.
the ss/sc takes 6 quarts..... make sure they are using 6, the idiots at my garage kept putting 5 in, and i had to add a quart about once ever 3 weeks..... been fine since they figured that out.....
importkiller
Sep 30, 2015 07:18 PM
