Vavle Cover Has Hole???
Old 06-29-2013, 01:31 PM
Twoozofjuice's Avatar
yeah man the way that oil looked i'd just do maintenance on everything lol
Old 06-29-2013, 01:32 PM
Powell Race Parts's Avatar
Looks like the chain dragged something up and it escaped. Broken chain guide bolt?
Old 06-29-2013, 01:34 PM
Originally Posted by dcrep06
oh man, i couldnt even remember if i removed mine or not, i dont think i did lol. pretty sure i just pulled the coil packs out. make sure u have the tool to pull off those oil line quick release fittings. that back one near the timing chain side is a pain in the dick and you wont be able to use the tool. i improvised using two small scribes.
Wrong info it's not a TC and your info does not apply
TxLonghorn#1's Avatar
Where are those oil line quick release fittings located?
Old 06-29-2013, 01:35 PM
dcrep06's Avatar
oh opps! didnt see it was a LSJ >_____< my fault, pay me no mind! lol.
Yeah it's a SC...so no need to look for those right
Old 06-29-2013, 01:46 PM
So here are the plugs...in the order that I pulled them out....notice the oil on one of them??? Anyone know why?
[IMG][/IMG]
Old 06-29-2013, 01:48 PM
buildmeanempire's Avatar
The plug well gaskets probably need replaced. That would be my guess on how oil is in there.
Old 06-29-2013, 01:57 PM
Mindrot's Avatar
I think the main concern right now should be the chain. Take that valve cover off. The valve cover seal probably got grenaded as well when the chain flipped out. Take it off!
Old 06-29-2013, 02:00 PM
Is there a fast ways to post pics on here while using my cell phone?
Old 06-29-2013, 02:02 PM
  #36
It's not the chain...close call
It's a ****** bolt that broke off from somewhere. Let me post the pics.
Yes..good call no cell is fucked up...thanks!
Last edited by TxLonghorn#1; 06-29-2013 at 02:02 PM. Reason: Automerged Doublepost
Old 06-29-2013, 02:04 PM
  #37
[IMG][/IMG]
Old 06-29-2013, 02:05 PM
  #38
Plug well gaskets from under the valve cover
[IMG][/IMG]
Old 06-29-2013, 02:17 PM
  #39
Cams...timing chain...dirt ass **** oil!!!...and a ******* bolt. Can anyone tell me where this came from. When I was looking at the cams and chain and rockers and etc....I was looking for the culprit and located under the timing chain closest to the fire wall, I found a bolt. WTFFFFFFFFF??? Please help me with this bullshit! Where is this bolt from?
[IMG][/IMG]
[IMG][/IMG]
Old 06-29-2013, 02:54 PM
  #40
So I found where the bolt came from. It's from the plastic guide for the timing chain on the right side closer to the super charger. It's a grayish color in the pic under the chain. It was loose when I was trying to move it. Do I really need to replace that chain guide? What should I do?
[IMG][/IMG]
Old 06-29-2013, 03:18 PM
  #41
Axelthered05's Avatar
rebuild engine and add a turbo while your at it but seriously that sucks dude
Old 06-29-2013, 03:48 PM
  #42
SalvageBaltSS's Avatar
yup, time to do a lsj turbo on that thing : )
Old 06-29-2013, 04:39 PM
  #43
Can I go without it or do I need to replace the bolt or replace the engine?
Old 06-29-2013, 04:43 PM
  #44
dcrep06's Avatar
if nothing else looks damaged replaced the bolt and V/C..........that sucks man. sorry for your luck dude. replace the other stuff to while your at it. gaskets and oil. how many miles is on it?
Old 06-29-2013, 04:52 PM
  #45
How would I replace that bolt? I would have to take off the chain and **** to get under that chain and gears. It a guide for the chain so would I need to replace the guid or it would be ok without the bolt?
Old 06-29-2013, 05:00 PM
  #46
matt638's Avatar
Originally Posted by mrbelvedere
could be a shitty casting
this is the performance section not my **** is broke section please post it the correct section
Problems/Service/Maintenance - Cobalt SS Network
is this guy the new CSS police?
Old 06-29-2013, 05:11 PM
  #47
Sunburst_SS's Avatar
need to replace the chain guide that the bolt goes through too.......looks like it's broken also.
hopefully you can get the rest of the bolt out of the block easily.
Old 06-29-2013, 05:13 PM
  #48
An *******!
Plus I'm using my phone since cobaltss.net has an app. So it's different from the actual site on a computer!
Old 06-29-2013, 05:14 PM
  #49
Is that hard to do? Looking at it seems like it's a pain in the ass to do.
Old 06-29-2013, 05:47 PM
  #50
Mindrot's Avatar
Looks like the rest of that bolt is going to have to be extracted. Looks like some of the bolt broke off when it came loose?
Quick Reply: Vavle Cover Has Hole???
