Vendor Help! 2.85" pulley!
Old Oct 12, 2006 | 11:42 AM
DWK5150's Avatar
Originally Posted by OniMirage
i would love to think we would be ok and having the injectors go static for only a second isn't going to do too much if any harm to anything specially since the next thing you do right after it goes static is change gears and put them back down to less duty
Yes I agree the only time I might be comcerend with that is if you were holding the motor at a constant 7,000 for a long period of time. We also need to remember that every vehicle is different and will resond a little differently as well.
Old Oct 12, 2006 | 11:45 AM
Matty's Avatar
If 82% is at 7000 don't worry. You shouldn't be bumping the limiter anyway. Shift anywhere from 6700-6900 and life will be good.
Old Oct 12, 2006 | 11:47 AM
R33P3R007's Avatar
360 L337 User
Originally Posted by ludicristSS
They where no more then 78-82% fine they did go 88-92% with the 2.7 over 6600 A/F would get up to 12.4-12.8 by 6800 and power would fall off 50lb injectors would work nice with a 2.7
Nope just that run on that car Non of the others did it 3 that day with 42lb 2 with 2.8 and one with 2.7
So technically, they tuned a 42 lb, with a 2.7.
I still think their tunes are too freaking expensive.
Old Oct 12, 2006 | 11:48 AM
DWK5150's Avatar
With the 2.7 though they were at 88-92% duty cycle thats getting high where I prefer not to be.
Old Oct 12, 2006 | 11:51 AM
patathSS's Avatar
just a question but how would either flow better if they can only send out 42.5lb/min. pressure is one thing but forcing something through a channel that only allows for a certain flow rate is still only going to yield that flow rate. This could be applied to water entering a tube from a larger tank. while the pressure before the tube would be higher than in the tube it can only flow to its maximum regardless of outside pressure until it breaks.
They are rated to flow that on a standard fuel rail pressure setup. Since an injector is pulse controlled, when you have greater pressure behind it, you are forcing more fuel through the pulse. Find any injector calculator and on order to compute your actual injector flow you need to know what your fuel rail pressure is. If your philosoph was true than boost-a-pump would be out of business.
Old Oct 12, 2006 | 11:55 AM
OniMirage's Avatar
this is true keep in mind the car has a built in safety feature which try as you might will not allow you to hold a constant rpm level for too long and it can vary rpm's by 500depending on the situation. remember that is per minute so you likely would never notice unless you could graph it while on cruise control in 4th gear at like 120 for a while
Old Oct 12, 2006 | 11:56 AM
DWK5150's Avatar
Here is a injector flow calculator for those that are curious.
http://www.rceng.com/technical.htm#WORKSHEET
CTCOBALTSSS's Avatar
Yeah 2.7 = Too small for 42's.
I think a 2.85" pulley would just be perfect. It would stay a little more snug in that GM stage 2 belt too.
Old Oct 12, 2006 | 11:57 AM
Nice find bro, I just don't know all the info to fill it in and calculate.
Old Oct 12, 2006 | 12:02 PM
DWK5150's Avatar
yeah 2.7 would be tab bit to small even for my likeing. You could probably have someone cust make you a 2.85 but I think it moight cost ya a pretty penny for it.
Old Oct 12, 2006 | 12:04 PM
  #36
OniMirage's Avatar
wow I had no idea what to put in the fields
Old Oct 12, 2006 | 12:05 PM
  #37
R33P3R007's Avatar
360 L337 User
People are running 2.7 and upping the rev limit. I am going to keep it at 7000 and shift before then anyway. I want the Smaller puilley for the increase in tq. If I have to I will install a MBC and limit it to 17lbs or so, and still shift early. I have my shift light set at 6450 anyway.
Old Oct 12, 2006 | 12:08 PM
  #38
Matty's Avatar
According to the chart 290 BHP is the max for the 42# injectors.
Old Oct 12, 2006 | 12:09 PM
  #39
DWK5150's Avatar
ok how about this one this one is good also.
http://www.stealth316.com/2-calc-idc.htm
Old Oct 12, 2006 | 12:10 PM
  #40
R33P3R007's Avatar
360 L337 User
holy **** does that look complicated
Old Oct 12, 2006 | 12:30 PM
  #41
Very intersting. 290bhp = 255-260whp.
Old Oct 12, 2006 | 12:34 PM
  #42
DWK5150's Avatar
I would say they are figuring a 10% drivetrain loss with that.
Old Oct 12, 2006 | 12:36 PM
  #43
Oh OK, then it would be about 265-270whp. That would be about these mods.
GM stage 2 w/2.85" pulley
Header
Downpipe
Cat-back
CAI
Old Oct 12, 2006 | 12:39 PM
  #44
DWK5150's Avatar
Header
Downpipe
Cat-back
CAI
No whp is wheel horse power. Thats what you would be putting to the ground. BHP is engine horsepower basically.
Old Oct 12, 2006 | 12:50 PM
  #45
Yeah yeah, my bad. I'm in the middle of lunch and trying to type. Can't multi-task sometimes.
I hope a vendor chimes in. Knowing what we know you would think they would want to make a 2.85" pulley because they would sell very well. Come on vendors.
Old Oct 12, 2006 | 01:10 PM
  #46
johnkb8's Avatar
2.85
2.85
2.85
2.85
2.85
2.85
awww come on man....wheres my 2.85
Old Oct 12, 2006 | 01:14 PM
  #47
Originally Posted by johnkb8
2.85
2.85
2.85
2.85
2.85
2.85
I'm with you bro, we just need a vendor's help.
Old Oct 12, 2006 | 01:24 PM
  #48
OniMirage's Avatar
2.85
2.85
2.85
2.85
2.85
2.85
Old Oct 12, 2006 | 01:28 PM
  #49
distillion's Avatar
just go the zzp route....
Old Oct 12, 2006 | 01:31 PM
  #50
johnkb8's Avatar
^^ we want the stock lookin pulley type
