Vendor Help! 2.85" pulley!
Old Oct 12, 2006 | 10:50 AM
CTCOBALTSSS's Avatar
Question Vendor Help! 2.85" pulley!
Hey vendors we need someone to make a 2.85" pulley that fits the GM stage 2 hub.
Can someone please make this for us? It would be greatly appreciated by all!
A 2.85" pulley will keep the 42lb. injectors just below 80% duty cycle @7,000rpm.
Tune Time Performance link. Click on the links next to the Cobalt.
http://www.tunetimeperformance.com/
Here is his thread.
https://www.cobaltss.net/forums/tune-time-performance-115/dyno-results-35070/
UPDATE!
Hey guys Jim@Tagracecraft can make us a 2.85" pulley but we need 10 people.
1. Me
2.
3.
4.
5.
6.
7.
8.
9.
10.
Originally Posted by Jim@Tagracecraft
hey Guys I think i might be able to help you fellows out with a 2.85 pulley
I would need a minimum of 10 pulleys to get anything started
Pm me and let me know
jim
Old Oct 12, 2006 | 10:53 AM
johnkb8's Avatar
haha i knew you would be making a thread like this, good luck!
Old Oct 12, 2006 | 10:55 AM
bigd2114's Avatar
80% duty cycle?
R33P3R007's Avatar
360 L337 User
Why not just use the 2.8
is .05 gonna make that much difference?
I am gonna run the 2.7 once i can get tuned
Old Oct 12, 2006 | 10:56 AM
You know it. Thanks bro.
Originally Posted by bigd2114
80% duty cycle?
Yes sir. Just under 80% @7,000rpm
Old Oct 12, 2006 | 10:57 AM
DWK5150's Avatar
Whats the duty cycle with a 2.8 pulley?
Old Oct 12, 2006 | 11:03 AM
Yeah it does make a difference. A 2.8" makes about 83% duty cycle and a 2.7" is up near 92%. Anything above 80% and the injectors can go static. It's just a safety precausion.
About 83% duty cycle @ 7,000rpm
Old Oct 12, 2006 | 11:05 AM
DWK5150's Avatar
83% in all honesty I wouldnt worry about. You will still be safe it snot like you are going to be holding the car at 7,000 rpm for a exteneded period of time.
Old Oct 12, 2006 | 11:07 AM
distillion's Avatar
i read a 2.8 made 100 percent at 6100 rpms last week?? lol
Old Oct 12, 2006 | 11:08 AM
Yeah I don't know who that was but I trust Tune Time Performance.
Old Oct 12, 2006 | 11:09 AM
Shortbus's Avatar
Reading and actual experience are two different things. I run a 2.7 and 42's.
Old Oct 12, 2006 | 11:13 AM
patathSS's Avatar
Did TTP use GM injectors? I have seen HPT logs with GM injectors and a 2.8 showing over 100% flow. My theory is that the Stage 2 injectors are 42 lb/min AT 60 PSI. The aftermarket injectors are all rated at a standard fuel rail pressure of 43psi. So the aftermarket 42s actually flow more. But to be sure you need to take YOUR car there and have YOUR car logged for this.
Old Oct 12, 2006 | 11:14 AM
And what's the duty cycle of your 42lb.ers @7,000rpm with that 2.7" pulley?
Old Oct 12, 2006 | 11:19 AM
distillion's Avatar
ya i read the graphs and info and his data logs, 2.8=100percent at 6100 rpm....
OniMirage's Avatar
just a question but how would either flow better if they can only send out 42.5lb/min. pressure is one thing but forcing something through a channel that only allows for a certain flow rate is still only going to yield that flow rate. This could be applied to water entering a tube from a larger tank. while the pressure before the tube would be higher than in the tube it can only flow to its maximum regardless of outside pressure until it breaks.
Old Oct 12, 2006 | 11:20 AM
They were gm injectors. The link is at the top.
OniMirage's Avatar
this would have had to have been before the updated tune and he was likely getting the lean false lean issue
Old Oct 12, 2006 | 11:25 AM
OniMirage's Avatar
you have a link to the graph? i dont see it unless im misunderstanding
distillion's Avatar
interesting....
Old Oct 12, 2006 | 11:28 AM
Where the heck did it go? This site is weird sometimes, let me go fix it. BRB!
Old Oct 12, 2006 | 11:32 AM
Ok all set!
The link is there on the first post now.
Old Oct 12, 2006 | 11:35 AM
DWK5150's Avatar
In his post with the 2.8 he said they only saw 78-82%. You will be ok with that or am I missing something here?
Old Oct 12, 2006 | 11:37 AM
Yep and that's from 5,500-7,000rpm. I want a 2.85" to stay just below that 80% mark @7,000rpm.
Old Oct 12, 2006 | 11:40 AM
OniMirage's Avatar
i would love to think we would be ok and having the injectors go static for only a second isn't going to do too much if any harm to anything specially since the next thing you do right after it goes static is change gears and put them back down to less duty
Old Oct 12, 2006 | 11:41 AM
OniMirage's Avatar
lol i said duty
