Vendor Help! 2.85" pulley!
Hey vendors we need someone to make a 2.85" pulley that fits the GM stage 2 hub.
Can someone please make this for us? It would be greatly appreciated by all!
A 2.85" pulley will keep the 42lb. injectors just below 80% duty cycle @7,000rpm.
Tune Time Performance link. Click on the links next to the Cobalt.
http://www.tunetimeperformance.com/
Here is his thread.
https://www.cobaltss.net/forums/tune-time-performance-115/dyno-results-35070/
UPDATE!
Hey guys Jim@Tagracecraft can make us a 2.85" pulley but we need 10 people.
1. Me
2.
3.
4.
5.
6.
7.
8.
9.
10.
Here is his thread.
UPDATE!
1. Me
2.
3.
4.
5.
6.
7.
8.
9.
10.
Originally Posted by Jim@Tagracecraft
hey Guys I think i might be able to help you fellows out with a 2.85 pulley
I would need a minimum of 10 pulleys to get anything started
Pm me and let me know
jim
jim
Why not just use the 2.8
is .05 gonna make that much difference?
I am gonna run the 2.7 once i can get tuned
Originally Posted by johnkb8
haha i knew you would be making a thread like this, good luck!
Originally Posted by bigd2114
80% duty cycle?
Originally Posted by DWK5150
Whats the duty cycle with a 2.8 pulley?
Did TTP use GM injectors? I have seen HPT logs with GM injectors and a 2.8 showing over 100% flow. My theory is that the Stage 2 injectors are 42 lb/min AT 60 PSI. The aftermarket injectors are all rated at a standard fuel rail pressure of 43psi. So the aftermarket 42s actually flow more. But to be sure you need to take YOUR car there and have YOUR car logged for this.
Originally Posted by Shortbus
Reading and actual experience are two different things. I run a 2.7 and 42's.
Originally Posted by distillion
ya i read the graphs and info and his data logs, 2.8=100percent at 6100 rpm....
In his post with the 2.8 he said they only saw 78-82%. You will be ok with that or am I missing something here?
