Vibrant Header/dp Leak?
Old Sep 26, 2010 | 02:35 AM
babyCobaltss's Avatar
Hey guys so i just put on my Vibrant header and Dp it sounded beastly open down pipe haha...but once i bolted it to the exhaust, it sounds like there is an exhaust leak? does anyone know about this or had this problem..where should Check?
Old Sep 26, 2010 | 02:54 AM
double check the bolts on the header, as u need to tighten again after the install
check the bolts on the downpipe header area
i have the vibrant header/dp and the vibrant 3in catback
had a leak at the header, and i had a few blown gaskets from the 3 bolt flange area where the dp meets the header haha
its a bitch tightening that top bolt haha
Old Sep 26, 2010 | 01:59 PM
Kyle_06_SS's Avatar
My vibrant header/dp has a leak at the top bolt too because I couldn't get it torqued down. If anyone knows of a good way to torque it down please speak up.
Old Sep 26, 2010 | 02:24 PM
some type of baby tools, i had a shop do it after it loosened up and blew the gasket
but i gave them a nut and bolt that wasnt like the one that was on there so it lasted for a lil bit
but i tighten it up about a month or less ago and just used a crescent wrench & a open end wrench
but some smaller tools would be easier, as the work area sucks haha
Old Sep 26, 2010 | 02:27 PM
boost_junkie16's Avatar
I cut an old wrench in half and then heated it and bent it to make it easier. It's still a pain to get it tight though..
Old Sep 26, 2010 | 05:22 PM
Alright..update time..so i got the bolt on the top where the dp/header bolt together pretty tight...but it still has a sight leak. i was wondering if it matters which way you put the dp on the header? Hard to explain but does the 3 holes where the bolts go have to match up to the header in a certain way? Sorry for the poor wording.
Old Sep 26, 2010 | 05:34 PM
u will know if u put the downpipe on the wrong way, the catback wouldnt bolt up
where do u hear the leak? if its at idle it could just be the injectors ticking(normal)
or do u hear it when u on the gas?
Old Sep 26, 2010 | 05:50 PM
Before i tightend it it was at idle...now its not at idle or barely audible...now its when im on the gas al the header bolts are tight as hell...th only bolt again would be the top on on the DP...which i cant tighten anymore
Old Sep 26, 2010 | 06:07 PM
if u want to, try a thicker gasket on the dp/header
autozone has a pack of 2 for like 8 buckets, 2.5inch collector gaskets
Old Sep 26, 2010 | 06:12 PM
SSinPA's Avatar
Could it be the flex pipe? I blew my vibrant then also blew my stock one.
Old Sep 26, 2010 | 06:19 PM
no i didn't blow it its brand new.
Old Sep 26, 2010 | 11:48 PM
On a side note, my clutch is starting to slip so..what would be the best clutch to get for under....say...600? any help?
Old Sep 27, 2010 | 03:31 AM
Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot
the gmpp clutch is a nice strong clutch
my tuner and his buddy both have it in their ion redlines
ones turbo swapped and the other is on 2.7 pulley i think
Old Sep 27, 2010 | 03:48 PM
well is it worth going and getting this one instead?
Clutchmasters FX200 Clutch Kit SATURN ION RED LINE 2005 - 2006 2.0 04-900-HDKV
Old Sep 27, 2010 | 08:26 PM
probably start a new thread about clutches so someone with experience with clutches can give u their feedback
to better your decision
Old Sep 27, 2010 | 10:26 PM
JetBlackSS's Avatar
I bought one of the gaskets from autozone mentioned above and paid $20 for a shop to tighten everything up. I had problems with bolts coming unscrewed no matter how tight I put them on. Shop double nutted it...lol
Old Sep 27, 2010 | 10:53 PM
**** ill have to try that i dont drive my car daily im in college about 2 hours away so its in storage now...
Old Oct 14, 2010 | 02:38 AM
Welll i thought it was tight but as soon as i drove it the next day the leak seemed to be back and when i get on the gas it kinda boosts then lessens boost then shoots up on boost ...hard to explain but its not a smooth flow of boost. any help? should i just take it to a shop?
Old Oct 14, 2010 | 08:46 AM
Stone629's Avatar
Make sure your O2 sensor is tightened. I've left them loose by accident a few times. Other than that, idk man. Sounds like you've been through everything. I was having the same problem, but since I've put a couple thousand miles on it, the leak has subsided a good 50%.
Old Oct 14, 2010 | 10:54 AM
Yea hahah everything is tight haha idk what it is im caling a shop today.
Old Oct 14, 2010 | 11:01 AM
do u let the car warm up?
it sounds like rasp and a leak if not warmed up all the way....thats with the 3inch cat back
if u dont have that dont worry about what i said haha
Old Oct 14, 2010 | 11:27 AM
Haha ya its a stock cat back still haha thanks tho!!
Old Oct 14, 2010 | 11:35 AM
i have the header/dp and catback and stock muffler right now haha cops didnt like it
so yea i have the stock muffler on and i sounds like its leaking, but i know i have a slightly blown gasket haha
i just tighten it back up as the other two bolts were fine, when i get some thing to help with that P0141 code, something about highflow cat and o2 sensor not getting enough airflow
must likely is leaking from the header and dp connection, so when u take it to the shop have the check the header too, to listen for air coming thru
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
