Vibrant help. Please..
Old Aug 13, 2008 | 07:41 PM
Perfect.disguise's Avatar
For people with the Vibrant header/Dp how did you get it on?I tried last weekend for a little bit and had trouble.Did you take off the heater hose on the left?How many studs did you have in the head?Any info you can give me to help out?
Old Aug 13, 2008 | 08:01 PM
chad463's Avatar
I believe there is about 10 syuds and the hose you have to move out of the way.
Old Aug 13, 2008 | 08:21 PM
I know there is 10 studs.I want to know if people had to take some out of the block and whatnot to get the header to fit. Also the top two center holes on the header dont have enough room between the nut and the primary to fit a socket what did you guys use?
Old Aug 13, 2008 | 08:25 PM
BeermanSSSC's Avatar
i didn't have that problem, just undid the hose to get it out of the way, pulled of the stocker and the heat shield, and slapped the new one on and bolted it up. You gotta use a 1/4 ratchet with a few different length sockets or extensions though. Much easier to get it fit.
the real bitch is the collector to dp bolts. those are a bitch to get a wrench on.
Last edited by BeermanSSSC; Aug 13, 2008 at 08:25 PM. Reason: Automerged Doublepost
Old Aug 13, 2008 | 08:32 PM
So it slides on perfect with all the studs in when you undo the hose? Did you have the problem about the socket not fitting on the nuts on the center top?As far as the hose I didn't notice and wont be able to check it out till this weekend but how does it come off? Is it just clamped?
Old Aug 13, 2008 | 08:48 PM
chad463's Avatar
I just unbolted the bracket and pushed it out of the way
Old Aug 13, 2008 | 10:00 PM
unbolt the bracket, undo the clamp and push that outta the way. Yeah it slids right on over the studs, all studs, and I didn't have any problems on the center ones. The hardest are the three furthest on the drivers side. They are a bitch to get a wrench on. And unless you have tiny hands you can barely get your hands on them.
Old Aug 14, 2008 | 06:16 PM
Haha well my hands aren't the smallest but I think I will do..Thanks for the help and I'm open to any other help.
Old Aug 14, 2008 | 09:30 PM
theneelster's Avatar
Paid FAR out the ass for the install.
Old Aug 14, 2008 | 09:32 PM
You did?
Old Aug 14, 2008 | 10:27 PM
chad463's Avatar
shops charge a lot for this install even though its just bolting it on.
Old Aug 15, 2008 | 12:30 AM
04redracer's Avatar
remove the studs. if you cant slip the header past the "hose" the studs unscrew from the manafold. if some come out when removing the factory header its normal. just remove the ones on the drivers side to ge the header in. does your vibrant header have the external exhaust lupe? is that why you cant get it on?
Old Aug 15, 2008 | 04:48 PM
Yeah, I tried that last weekend but you have to screw the studs straight in and with the header on my hands weren't small enough to get them all in.I will just undo the hose tomorrow, scew in all the studs, slide the header on and tighten all the nuts..
Old Aug 15, 2008 | 06:30 PM
Stouffer's Avatar
X2 and helps if you have air ratchet
Old Aug 15, 2008 | 09:04 PM
Well I already have everything off and first thing tomorrow I'm goint to retry.I guess I'm going to take the hose loose and push it out of the way then screw in the 7 studs that came off back in(loc-tight aswell)..put on the gasket then the header and tighten the nuts down.Then install the hose and D/P. Like I mentioned before I got it bolted up last weekend half way but couldn't get my hands in good enough to get 3 or 4 studs.While it was up I tested the D/P and didn't have a problem with the nuts.
Old Aug 15, 2008 | 09:42 PM
I'm not sure I would loc-tite your studs into your block, but good luck with the install man, your gonna love it when your done, do you have a wb bung installed in it already? If not you might want to get one in the dp before you bolt it in, save you from having to take it off, if/when you get a wideband.
Old Aug 15, 2008 | 09:56 PM
I'm just using the blue medium strenght.It had a little on it to begin with so I figured I might as well use it back.It will be a while before I get a W/B and I have to add a new cat anyways so it's ok.
Old Aug 15, 2008 | 10:16 PM
cool, good luck man.
Old Aug 16, 2008 | 08:40 AM
04redracer's Avatar
its way easer to do everthing from under the car
Old Aug 16, 2008 | 12:35 PM
Yes, the only way to get the header in is from under the car....
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
twilson380
Sep 14, 2015 10:52 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
