Wanting to go farther
Well i recently installed my Injen CAI i love it now i wanna know what to do next i do wanna do a stage 2 zzp kit but what should i get before all that maybe an exhaust, HE, what would be the best route to go if u were going to install something next after an intake...also while on a budget lol
think about dropping the pulley size, bigger injectors if you do, and a tune.
also consider your cooling needs, you could get a heat exchanger, option b with Dual pass (or single pass), Meth? E85?
Your flow is also something you should consider, header, exhaust, downpipe..
i was thinking a ZZP s3 with 2.8 pulley #60 injectors dual pass endplate s3 h/e tune but im trying to figure what exhaust i want gimmie some idea's something deep but not farty u know what i mean maybe magnaflow? or zzp's exhaust idk
Well in all honesty when it comes to exhaust setups, it all depends on personal preference. Currently I have a mgnaflow catback with a resonator. Stock dp and manifold and it sounds great in my opinion. its got a great deep tone to it. Others will beg to differ on this setup because most hate the sound of a magnaflow on the superchaged engines. All the really good systems will more then likely cost you an arm and a leg and those would be borla, corsa, gmpp.
For a few hundred dollars I would get a ZZP 3" CATTED-downpipe, ZZP S3 heat exchanger, and if you have any money left, get some rotated mounts or other traction mod. That would be a decent start. I always do supporting mods first, THEN you can safely increase power ie; smaller pulley, larger injectors, and a GOOD TUNE! Hope this helps!
Iceberg
Sep 29, 2015 12:33 PM
