Water Injection, Pros and Cons???
Old Jun 28, 2006 | 06:32 PM
SSpartan's Avatar
got my interest
hey patath youve got my attention.
i wanna see this cooler kit too!
Old Jun 28, 2006 | 06:39 PM
SRT-4_UK's Avatar
This is a quote taken from the srt forums.
Originally Posted by FASTATTACK
What is water injection?
Water injection is a technology that is nearly as old as the car itself. However, like many automotive technologies, it has waxed and waned as fashion has dictated. Water injection has the ability to suppress detonation, allowing the use of higher cylinder pressures. It is easy to control and relatively simple to install. In times of tight emission controls, decreasing fuel octane and rising petrol costs, water injection is one of the best ways of controlling detonation. And it has another major advantage over taking other approaches - the 'fuel' is available at almost zero cost!
How it Works
Water injection is used to suppress detonation. Detonation occurs when the flame front does not burn progressively across the combustion chamber but instead explodes into action. This causes a massive and sharp increase in combustion pressures which can damage pistons, rings and even heads. Detonation can sometimes be heard as a 'tink, tink' sound coming from the engine. The piston and head shown here has suffered severely from detonation.
Water injection works in three ways. Firstly, when the water is injected into the intake system prior to the cylinder head, the small droplets absorb heat from the intake air. Water has a very high specific heat rating (it can absorb lots of energy while only slowly increasing in temperature) and so the intake air is initially cooled. Next, the small drops of water start to evaporate. Water has a very high latent heat of evaporation (its change of state absorbs a lot of heat) and so the intake air charge is cooled still further. Finally, when the remaining water droplets and water vapour reach the combustion chamber, steam is produced. This acts as an anti-detonant and also keeps the interior of the engine very clean, so preventing the build-up of carbon "hot spots".
Water injection was first experimented with in the 1930s. At the time it was discovered that detonation could initially be prevented by enriching the air/fuel ratio. As cylinder pressures rose still further and that approach ceased being effective, the injection of water into the intake air stream was found to prevent detonation. Interestingly, the detonation remained suppressed, even if the air/fuel ratio was then leaned-out. This occurred because the excess fuel was being used to cool the combustion process. When water replaced fuel in performing this function, less fuel was then required.
This has major implications for both emissions and fuel economy at high engine loads. In fact Saab on some of their recent turbocharged cars has used water injection at high loads in conjunction with leaner air/fuel ratios to reduce emissions output and improve fuel consumption. To put this another way, at high engine loads it is possible to reduce the amount of fuel being used, replacing it with water without sustaining any loss of power!
--excerpt from autospeed.
So what is alky and methanol injection relate to water injection?
well they are the same , the diffrence is the type of liquids used on the resovoir.
Methanol has ability to act as a secondary fuel as well as a very fast cooling agent, problem is that 100% methanol is very expensive and its not feasable to run every day
Alky , is a type of alchohol used primarly to decrease the temperatures of the charged air , although cheaper than methanol , it will vaporize a lot faster than methanol or water thus not having the same level of efficiency in cleaning your motor and preventing detonation.
Hopefully that will shed some light on the situation.
Old Jun 28, 2006 | 06:42 PM
zinner's Avatar
Moderator Alumni
I think the biggest con is no one has been able to show it give you any more power/performance.
Unless you are upping the boost or adding timing to some sick new level, not even the guys running the smallest pulley have needed to use water injection.
Old Jun 28, 2006 | 06:45 PM
player_1's Avatar
I've always thought of it as more of a protection type mod, kinda like keeping your engine is safe operating condition, while your boosting the hell out of it in other places. lol
Old Jun 28, 2006 | 06:47 PM
CynicX's Avatar
I'm running a methanol setup...tuned got me about 30/30 hp/tq...results are pretty awesome...
If you are interested in setups goto www.nasioc.com and too the water/meth/alky section...you can read stuff for days...
Biggest thing to do is check pump operation...dont just throw it in there and try it...use the proper guage wire, pull amp draws, check voltages, solder connections etc etc....my meth pump is properly the most reliable thing on my car
Old Jun 28, 2006 | 06:48 PM
Matty's Avatar
These work well with Vortechs.
http://www.vortechsuperchargers.com/products/coolers/
SRT-4_UK's Avatar
It is possible to tune the car for water meth but the safest way is to activate a "high boost mode" while it is pumping to get the full effect of what the water meth is doing inside the engine.
Old Jun 28, 2006 | 06:50 PM
zinner's Avatar
Moderator Alumni
I was refering to the cobalt ss/sc application not other cars. I have heard the same thing about meth injection on subaru's
CynicX's Avatar
basically what I'm doing...but I increase boost, advance timing and a ton of other things the tuner did....
I change the tune on the track and change it back when I leave...
Old Jun 28, 2006 | 06:53 PM
CynicX's Avatar
although s/c vs turbo the theory is the same. I dont know how tuning ss/sc's are but they have a ton of really nice realible setups that will work in either application...
Old Jun 28, 2006 | 06:54 PM
  #36
SRT-4_UK's Avatar
That is the proper way to go about things.
Just bolting it up to the ss/sc will still produce gains. Rember, it raises octane and makes colder air. Even without tuning for meth, there are still gains to be had.
Old Jun 28, 2006 | 08:03 PM
  #37
patathSS's Avatar
This is what I am trying to do. Making 19 lbs of boost isn't easy on the motor and the supercharger heats the air up so fast it is incredible. I am trying to prevent as much heat soak as possible right now. I am running an icebox, I am going to wrap my exhaust header, and hopefully now run water injection. I know of some guys who have had success on their Impalas using W/I before the supercharger. (Hint, hint maybe he can chime in )
My big question is which is more effective, before the SC or after? I really don't want to wait for an injection plate but I am not going to tap my intercooler or supercharger for a nozzle. For now I think I am going to tap my Injen intake and run it through the supercharger. Then, if Intense releases an injection plate, I will run a second nozzle to their and look at upgrading my setup to a two stage injection style.
Old Jun 28, 2006 | 08:06 PM
  #38
patathSS's Avatar
Yeah, I really want to increase my timing with it. The **** degree of timing I run in third makes me want to puke when I look at the logs. Actually how low my timing is across the board makes me mad.
Old Jul 6, 2006 | 05:21 PM
  #39
SnowTech.3's Avatar
We (Snow Performance) have found you can inject before or after an Eaton, but injecting before REALLY helps maintain a cooler rotor and housing temperature.
Injecting after the blower (and throttle body) is fine - and we can tailor a kit for 4 nozzles, etc. but would require a shut-off solenoid because the vacuum that is created when the engine is running and the throttle is closed would siphon fluid without a solenoid.
We typically see inlet temps drop around 60-100 degrees, but I haven't heard back from the Cobalt SS user that is running it for exact numbers. I can say that running 50/50 water-methanol and 91 is roughly equivalent to 116 race gas, so you can run comparable boost and ignition timing.
Old Jul 6, 2006 | 05:26 PM
  #40
player_1's Avatar
so I gues this means that you have already developed a kit specificaly for the cobalt, any idea on realease dates?
and will you be making an after blower kit aswell?
Old Jul 6, 2006 | 06:02 PM
  #41
SnowTech.3's Avatar
The only changes needed to the kit for pre-blower are the nozzle sizes. For after blower, we add a solenoid, and potentially 3 additional nozzle upgrades and 2 additional nozzles. Depends on where you want to inject.
Old Jul 6, 2006 | 06:38 PM
  #42
SRT-4_UK's Avatar
See and nobody believed me until Snow makes an apperance. lol
Old Jul 6, 2006 | 06:55 PM
  #43
SnowTech.3's Avatar
Heh heh. You were doing fine, IMO. It is just sometimes better to outflank than staying in one position.
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Highgross89
20
Sep 11, 2015 03:24 PM
