Water/Meth before blower
Old Mar 17, 2011 | 09:19 AM
jakeLSJs2's Avatar
I have a watermeth kit i bought and am planning on running it after the throtle body before the blower. I also plan on using -20 washer fluid. Anybody else using this same set-up and see good results or problems?
Old Mar 17, 2011 | 09:24 AM
Erod's Avatar
Moderator Alumni
this goes in PERFORMANCE moved
Old Mar 17, 2011 | 10:53 AM
Bluelightning's Avatar
Got Bewst?
Thats the current set up i am currently running. I love being able to do a pull and i can put my hand on my charger and it will be cool to the touch. I also gained 2 pounds of boost running it through the charger. The windshield washer fluid cools well but theres not enough meth in it. I'm going to be swaping to 50/50 this spring.
Old Mar 18, 2011 | 01:21 AM
goeckeritz123's Avatar
What washer fluid do you run
Old Mar 18, 2011 | 01:34 AM
06arrivalSC's Avatar
I use a 50/50 ish mix, its consistent each time which is important...but i use Peak or Valuecraft...aka Autozone washer fluid made by Peak lol
I think washer fluid is about 20-25% meth if im correct...if im wrong, correct me lol
Essential to make sure the ingredients is only water and methyl alcohol, no additives or anything else
Old Mar 18, 2011 | 02:42 AM
Omnigear's Avatar
pif man up n 90/10 ^_^
Old Mar 18, 2011 | 02:46 AM
Ting-ting's Avatar
i want meth im just hella confused by how to run it and wtf to make it with haha
Old Mar 18, 2011 | 03:07 AM
Same i need to be schooled lol
Old Mar 18, 2011 | 02:36 PM
Got Bewst?
You would run a winter windshield washer fluid. It contains methanol so that it doesn't freeze. But it's a low amount of meth.
Confused how to run it in what way? To make it you are just taking methanol and mixing it with distilled water. Now you can change you're ratio for different applications. 50/50 is probably the most common
Old Mar 18, 2011 | 06:54 PM
Omnigear's Avatar
if you want ponies up the meth if you want cooling up the h2o
Old Mar 18, 2011 | 07:00 PM
carstedt's Avatar
i use the -25 washer fluid (blue in color) and then add bottles of HEAT...it also contains sum methanol so u can up the percentage
Old Mar 18, 2011 | 07:09 PM
Ting-ting's Avatar
Im confused on all of it haha
Old Mar 18, 2011 | 07:11 PM
Blown07SS's Avatar
I might try this so u mix 25 peak fluid and what percent water or just peak fluid. I might just run 50/50 but might try this out till the weather gets better to play around in
Old Mar 18, 2011 | 09:26 PM
Got Bewst?
Maybe this will help
Water/Methanol Injection FAQ - NASIOC
Old Mar 18, 2011 | 09:35 PM
thebucky84's Avatar
i still have to weld my reservoir, hopefully i can get around to doing it this weekend. I'll be using 50/50 boost juice when i'm done.
Old Mar 18, 2011 | 10:11 PM
ULWizSS's Avatar
I decided to get the ZZP M62 Plate to Inject my Meth. Its gonna raise the blower a little so i had to buy a stock belt as well. I am running a 75/25 mix of VP M1 and Water.
Old Mar 31, 2011 | 05:39 PM
You arent mechanically pushing any more boost. Assuming its the same pulley as before you were running meth, the blower is still spinning at the same revolutions per unit time throughout the rpm range and compressing/pushing the same amount of air into the intake manifold as before. The cooler intake charge from the meth/water is what causes the car to perceive that its seeing more boost. My winter tune was just a conservative 93 octane tune, but when I was running meth through the end of summer I was pushing "17psi" whereas before it was seeing around 14-15psi with the same GMS3 pulley I had before meth.
What exactly are you confused about? lol be more specific, confused about what to buy? confused about how to install? confused about what kind of setup you want with it? confused about the tuning aspect? lol
Old Mar 31, 2011 | 06:15 PM
Got Bewst?
Actually even Devilsown will tell you you're boost will go up running meth because the meth/water tightens up the tolerences in the blades thus making more boost.
Old Mar 31, 2011 | 06:19 PM
ULWizSS's Avatar
Will find out myself in a few days when i get my ride back. Was boosting 17.5 before the badmab was put in. After that i went to s a solid 17. Now meth is going in so if it changes i will make another post.
Would be interesting to see though since i honestly have no idea.
Old Mar 31, 2011 | 06:28 PM
Got Bewst?
It will go up. And it makes sense as to why too. I was 15 psi with my 2.8", hooked up my meth and went to 17psi
Old Mar 31, 2011 | 11:17 PM
Hmmm...interesting...I guess it doesnt make sense to me as to how a mist/vapor would cause the rotors to "mesh" closer or have a tighter clearance or tolerance...but it's not like I have anything to prove that theory wrong lol it just doesnt make sense to me
Old Apr 1, 2011 | 02:04 AM
Got Bewst?
Vaporizing meth and water through a supercharger creates a tighter seal. It's not that complicated haha.
Old Apr 1, 2011 | 03:09 AM
I know what you're saying lol I'm just saying it doesn't seem like a vapor would cause a tighter seal to a noticeable degree of 1-2 psi lol
Not saying you're wrong, would like to see/read more on this though out of curiosity lol
Silverbullet333
Oct 4, 2015 02:27 PM
jimbofug007
Oct 2, 2015 12:06 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
