water/meth boost activation switch
Old Nov 17, 2008 | 10:56 AM
ralliartist's Avatar
Ok so here is the one I got.....
It doesn't work. I've ordered a second one and still had problems with it. So I DON'T want that switch anymore. I got my meth system rigged right now into the cabin and I just press a switch with my hand to activate it as I get on the throttle right now. It's ghetto and I don't like it. So if you have a different boost activation switch other than the one I posted, give me a link so I can check it out and hopefully get a new one that works.
Old Nov 17, 2008 | 11:07 AM
deuce's Avatar
PM ajSS, his comes on with boost i believe
Old Nov 17, 2008 | 11:12 AM
PhantomSS's Avatar
i use MAF activation
Old Nov 17, 2008 | 11:22 AM
what do you use to do that?
Old Nov 17, 2008 | 11:42 AM
deuce's Avatar
possibly a pressure switch?
Old Nov 17, 2008 | 11:53 AM
2K5SS/SC?'s Avatar
Use the Devil's Own one if that isn't working for you. Mine work great and it's easily adjustable. I just installed a AIS kit for someone and that switch worked great though. Top two prongs are the ones you'll use, and hook it up to the vacuum line coming directly off the intake manifold.
Old Nov 17, 2008 | 12:05 PM
PhantomSS's Avatar
snow performance stage 2 has 2 options. boost, or maf activation. It just reads the maf voltage and compensates to the pump.
Old Nov 17, 2008 | 12:08 PM
invisible's Avatar
I use map activation.
Old Nov 17, 2008 | 12:12 PM
qwikredline's Avatar
I suggest you contact OTTP Josh buddy. I use an adjustable boost activation control switch real easy 100% reliable, with a 5 gpm nozzle from Josh a Devils Own part that is superior to the cooling mist one i had. I would prefer a progressive controller, so i just got that from Josh have not installed it yet.
Old Nov 17, 2008 | 12:40 PM
I don't want a progressive controller. I also don't want to keep having to press a button everytime I want to get on it. I'd rather it do it by itself. I'll call josh. But in the meantime, anyone got any links to something else?
Old Nov 17, 2008 | 03:18 PM
invisible's Avatar
Why not a progressive controller? I love mine.
Old Nov 17, 2008 | 04:36 PM
2K5SS/SC?'s Avatar
http://www.alcohol-injection.com/wat...-switch-1.html
The 6-30 psi switch. Install it, set it, and go. Done!
Old Nov 17, 2008 | 07:35 PM
Ryze's Avatar
I have the same switch no problems yet
Old Nov 17, 2008 | 07:50 PM
Dainslaif's Avatar
Second this.
Old Nov 17, 2008 | 07:56 PM
Originally Posted by Dainslaif
Second this.
there you go Dainslaif, agreeing with me. Again
Old Nov 18, 2008 | 01:19 AM
Don't want progressive. It's all about the tune. Spray all of it starting down low and you can get the car lean down low and build the tq up quicker. I talked to josh, I'm gonna get their little activation switch. It's similar but more durable.
Old Nov 18, 2008 | 02:07 AM
Sharkey's Avatar
no problems here with the devils own switch. kinda funny how you have 2 switches not working. i know it is a dumb question, but you are hooked into the correct vacume line right???
Old Nov 18, 2008 | 02:09 AM
Steven Flit's Avatar
That looks like the AIS basic boost switch.
I use it and it works great
Old Nov 18, 2008 | 11:42 AM
doesn't work for me. The first one I had did work, but it broke somehow on the inside. It has a piece that rattles now. So I got a new one and it doesn't work at all.
Old Nov 18, 2008 | 01:04 PM
Sttange...
its a really simple cheap part
if you ordered it from AIS
why not call and let Rodney know it doesn't work.
Old Nov 18, 2008 | 04:33 PM
Area47's Avatar
Rent me! per hour
hobbs switch from napa. part number
701-1575
Old Nov 18, 2008 | 06:02 PM
HOT CARLS SS's Avatar
RAW has a kit with a boost activation switch and you set it with a small allen key for how much boost you want it too turn the pump on at. I have it set too 6psi and it works awesome no problems for 2 yrs....Love the RAW kit.
Old Nov 18, 2008 | 06:13 PM
hungryhip-ccp's Avatar
did you check to make sure your lines havent rubbed threw? it took mine just over a year to rub threw and i wa losing boost signal to the switch... went to home depot grabbed some line for $4 and called it fixed...
i am using that same ais switch with no prob for over a yr
Old Nov 18, 2008 | 06:14 PM
1badBlueberrySC's Avatar
701-1575
TROOF! I am running this same switch as is Area47
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
