Water Methanol Injection Kit.......
Old Aug 17, 2006 | 06:44 PM
Rangerondubz's Avatar
Alright since the Water Methanol Injection Kits run off of a full throttle position sensor how is that going to apply to the Electronic Throttle Body that LSJ has. I know some of the high boost guys have it on here, so how did you wire it, through a push button switch? Thanks in advance for the help guys, Preach
Old Aug 17, 2006 | 07:14 PM
selfinfliction's Avatar
can run two ways,
the cheap way (the way mine wa slast year) runs off of a boost sensor. mine kicke don between 6-8 psi
the best way runs off of the maf sensor
Old Oct 4, 2006 | 02:31 PM
srt-killer's Avatar
Originally Posted by selfinfliction
can run two ways,
I am planing on getting the water injection kit some time next week. Were is the boost sensor located and how do you set the kit to turn on at a certin boost level.
Old Oct 4, 2006 | 02:47 PM
Blown 4-banger's Avatar
The Snow performance one goes off the MAF sendor, and the Devils Own one goes off boost (1 bar, 2 bar, 3 bar)
Old Oct 4, 2006 | 09:27 PM
JCswoosher2's Avatar
so this is running full time? or does methanol only spray when u want it to
Old Oct 5, 2006 | 01:12 AM
2K5SS/SC?'s Avatar
Methanol only sprays when you hit a certain PSI. The boost sensor one is adjustable in that you select at what PSI you want it to come on at. Pretty easy to adjust to, just turn the dial ot the preset amount of boost as it's attached to a vacuum line. Spraying methanol all the time would be a waste of it. I think setting it at 6 or more psi would be fine, but it's up to you. The MAF sensor one progressively sprays the methanol in relation to how you have it adjusted so you can increase and decrease the amount of flow at different air rates. This is great for tuning when trying to get more HP.
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
SlowSaturn
Sep 28, 2015 11:03 AM
roadrunner132
Sep 16, 2015 09:13 AM
