Weapon R intake install ?
i got a 05 SS/SC about 2 weeks ago and ordered the weapon r secret weapon cai which comes with a ram kit. looking at my engine im lost tryna figure out how 2 put it on. i saw a how to for a injen model that said somethin about takin off the wheel and the pullin out the fender liner would that be the same for this and is there any extra steps to make the ram kit come out in front of the h/e
Is it the dragon short ram or the secret weapon.
The secret weapon should install the same is says this sbout the intake:
The velocity stack inside the filter is a true velocity stack. Ram air capabilities can be achieved by hooking up the hose to the top of the air filter.
The components in the Ram Air kit are all computer designed and made from plastic to resist heat soak, which robs horsepower from your engine. To install this unit is simple, first you bolt the Ram Air Adapter to the top of your Weapon R Dragon Intake Filter.
After you have done that, using the mounting kit you mount the Ram Air Scoop to any part of your car, which gets constant rushing cold air. Next you route the Heat resistant 3" Ram Air Hose from the Scoop to the Ram Air Adapter on top of your Weapon R Dragon Filter. Your car is now equipped with a Ram Air Intake.
So according to that, you can run the ram anywhere there is cool air. so yea install it as normal then run and mount the ram part, if your looking at the front of the car try to install it in the right side of the opening in the front of the car, just be careful when it rains..
OrangeCoba
Sep 25, 2015 06:06 PM
